StarTech.com 1 ft Cat5e Blue Snagless RJ45 UTP Cat 5e Patch Cable - 1ft Patch Cord
Quicklinx: 8CPCWS00 Mfr#: RJ45PATCH1
Make Fast Ethernet network connections using this high quality Cat5e Cable, with Power-over-Ethernet capability. The RJ45PATCH1 Cat5e patch cable (1ft) meets or exceeds all Cat 5e cable specifications to ensure reliable Ethernet network connections, and features a durable blue PVC jacket that enables you to color code your network cable runs as needed.
To ensure long-lasting performance, this high quality Cat5e patch cable features a snagless design that protects the RJ45 connector clips from damage and makes the cable less prone to snagging during installation. The cable also features molded PVC strain relief that prevents the RJ45 connector termination points from bending at sharp angles, reducing the risk of cable failure.
Get the highest value for your cable investment with the Cat 5e cables, each one manufactured using high-quality copper conductors.
Rely on the RJ45 connectors to deliver optimum conductivity while eliminating signal loss due to oxidation or corrosion.
  • Snagless RJ45 clips help protect your network connections
    For easier cable runs, the snagless connectors protect the cable's RJ45 clips during installation, making them less likely to snag or break. This ensures a sturdy connection by preventing the cable from becoming loose from the port. The cable features moulded boots that offer connector strain relief, by stopping the RJ45 connector termination points from bending at sharp angles, and reducing the risk of damage to the cable, which could decrease network performance.
  • 100% copper for outstanding value
    Get the highest value for your cable investment with our Cat 5e cables, each one manufactured using high-quality copper conductors.
  • 24-gauge wire for high-performance network connection
  • 50-micron gold connectors provide peak conductivity
    Rely on our RJ45 connectors to deliver optimum conductivity while eliminating signal loss due to oxidation or corrosion. The RJ45PATCH1 is backed by StarTech.com's lifetime warranty for guaranteed reliability.
StarTech.com Cat5e Ethernet Cable1 ft - Blue - Patch Cable - Snagless Cat5e Cable - Short Network Cable - Ethernet Cord - Cat 5e Cable - 1ft - patch cable - 0.3 m - blue
Patch cable - CAT 5e
Unshielded twisted pair (UTP)
Wires per Cable
8 wires
Snagless
Length
0.3 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Blue
P/N: DKT30CHVCM, DKT30CHVGPD, DKT30CHVPD2
Network Cable Type
American Wire Gauge (AWG)
24
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Snagless
Length
0.3 m
Blue
Connector
RJ-45 - male
RJ-45 - male
