StarTech.com 1 ft Cat 6a Gray Shielded Molded 10 Gigabit RJ45 STP Cat6a Patch Cable
Quicklinx: 7B59WS00 Mfr#: C6ASPAT1GR
Length: 30cm
Colour: Grey
17 in stock
£6.11 ex VAT
£7.33 inc VAT
Make 10Gb Ethernet connections with PoE support. This high quality (gray) 1ft Cat 6a cable (STP) ensures dependable Ethernet connectivity, supporting 10 Gigabit performance up to 500 MHz - double that of standard Category 6 cable and five times the bandwidth offered by Cat5 - an excellent choice for Power over Ethernet (PoE) applications.
All of Cat 6a cables are constructed of high quality 25 AWG shielded copper pairs to protect against noise and EMI/RFI interference, ensuring that Cat 6a cables are more than suitable for 10GBase-T Ethernet networks and Power over Ethernet applications.
StarTech.com Cat 6a patch cables provide end-to-end solutions that are tested for compliance with all TIA/ETL-568-B2.10 Category 6, UL 444 and ROHS 2002/95/EC specifications.
StarTech.com 1ft CAT6A Ethernet Cable, 10 Gigabit Shielded Snagless RJ45 100W PoE Patch Cord, CAT 6A 10GbE STP Network Cable w/Strain Relief, Gray, Fluke Tested/UL Certified Wiring/TIA - Category 6A - 26AWG (C6ASPAT1GR) - patch cable - 30 cm - grey
Patch cable - CAT 6a
Shielded twisted pair (STP)
Wiring Scheme
T568B
Shielding Material
Aluminium-polyester foil
Wires per Cable
8 wires
Molded
Length
30 cm
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Grey
Network Cable Type
Wiring Scheme
T568B
Shielding Material
Jacket Material
PVC
American Wire Gauge (AWG)
26
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Molded
Length
30 cm
Grey
Connector
RJ-45 - male
RJ-45 - male
UL 444, RoHS - up to 500 MHz
Length: 30cm
Colour: Grey
Price Range Ex VAT: 0 - 50
