StarTech.com 1 ft Cat 6a Blue Shielded Molded 10 Gigabit RJ45 STP Cat6a Patch Cable
Quicklinx: 7B58WS00 Mfr#: C6ASPAT1BL
Make Ethernet connections with PoE support. This high quality cable ensures dependable Ethernet connectivity, supporting high level of performance is an excellent choice for Power over Ethernet (PoE) applications. All of the Cat 6a cables are constructed of high quality shielded copper pairs to protect against noise and EMI/RFI interference, ensuring that the Cat6a cables are more than suitable for Ethernet networks and Power over Ethernet applications.
StarTech.com 1ft CAT6A Ethernet Cable, 10 Gigabit Shielded Snagless RJ45 100W PoE Patch Cord, CAT 6A 10GbE STP Network Cable w/Strain Relief, Blue, Fluke Tested/UL Certified Wiring/TIA - Category 6A - 26AWG (C6ASPAT1BL) - patch cable - 30 cm - blue
Patch cable - CAT 6a
Shielded twisted pair (STP)
Wiring Scheme
T568B
Shielding Material
Aluminium-polyester foil
Wires per Cable
8 wires
Molded
Length
30 cm
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Blue
P/N: ST1000SMPEX
Network Cable Type
Wiring Scheme
T568B
Shielding Material
Jacket Material
PVC
American Wire Gauge (AWG)
26
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Molded
Length
30 cm
Blue
Connector
RJ-45 - male
RJ-45 - male
UL 444, RoHS - up to 500 MHz
P/N: ST1000SMPEX
