StarTech.com 1.8m USB 3.1 5Gbps with PD (5A) C to C Cable - M/M Certified
Quicklinx: DZ7GWS00 Mfr#: USB315C5C6
Length: 1.8m
42 In Stock
£25.00 ex VAT
£30.00 inc VAT
Power your USB Type-C devices over longer distances. With up to 5A (100W) of power output, you can use this USB-C to USB-C cable to power and charge a USB-C laptop, such as your Apple MacBook Pro, MacBook or Chromebook Pixel, using a USB-C wall charger, car charger or power bank. Or, you can power your laptop from a USB-C docking station. You can also power your USB-C hard drive from the USB-C port on your laptop.
The 5A of Power Delivery lets you charge your mobile devices faster than with a regular USB-C 3.0 cable, which is perfect for people on the move. Decrease your charge times and make sure your mobile devices are ready, whenever you need them while you're on the road.
The cable supports full 4K 60Hz video and DisplayPort 1.2 and is compatible with existing DisplayPort displays. It's ideal for connecting your docking station or laptop to a monitor with astonishing resolution, contrast, and color depth for amazing detail.
The USB Type-C cable has undergone rigorous compliance testing and is certified by USB-IF (USB Implementers Forum) to meet all USB 3.0 specifications. This includes all environmental, electrical and mechanical standards, which ensures a reliable and high-quality cable for all of your USB-C devices.
  • Fast-charge your mobile devices
  • Deliver full 4K video
  • Provide superior connections with USB-IF certified cables
    The USB Type-C cable has undergone rigorous compliance testing and is certified by USB-IF (USB Implementers Forum) to meet all USB 3.2 Gen 1 specifications. This includes all environmental, electrical and mechanical standards, which ensures a reliable and high-quality cable for all of your USB-C devices. The USB315C5C6 from StarTech.com is backed by a 2-year warranty for guaranteed reliability. This product works with devices capable of running the latest version of Chrome OS and has been certified to meet Google's compatibility standards. Google is not responsible for the operation of this product or its compliance with safety requirements. Chromebook and the Works With Chromebook badge are trademarks of Google LLC.
StarTech.com USB C to USB C Cable - 6 ft / 1.8m - 5A PD - USB-IF Certified - M/M - USB 3.0 5Gbps - USB C Charging Cable - USB Type C Cable (USB315C5C6) - USB-C cable - 24 pin USB-C to 24 pin USB-C - 1.8 m
USB-C cable
4K support, Power Delivery (PD) technology, up to 100 Watts of power delivery, 5 Gbps data rate
Length
1.8 m
Connector
24 pin USB-C - male - straight
Connector (Second End)
Rated Current
5 A
USB 3.0
P/N: DK30C2DAGPD, DK30C2HAGPD, SV211HDUC, SV221HUC4K
USB-C cable
Shielding Material
Jacket Material
PVC
American Wire Gauge (AWG)
32/34
Rated Current
5 A
Plated Connector
Nickel
Length
1.8 m
80 g
Connector
USB 3.0, RoHS, USB-IF, WEEE
Shipping Weight
85 g
DZ7G StarTech.com 2m USB 3.0 C Cable w/ PD (3A) In Stock £14.59
Length: 1.8m
