Discover the power of high-speed connectivity with the StarTech.com 50cm (1.6ft) USB4 Cable. Designed for superior performance, this USB-IF Certified USB-C Cord offers an impressive 40Gbps data rate, making it perfect for demanding data transfer, video streaming, and charging needs. With support for up to 240 watts of power delivery, it ensures your devices stay charged and ready for action.
Enjoy crystal-clear, high-resolution video with 4K120Hz and 8K60Hz support, alongside HDR and Display Stream Compression (DSC) for a high-quality viewing experience. The cable's compatibility with DisplayPort Alternate Mode 1.4 and its EMI protection feature ensure a reliable, interference-free connection.
Built to last, this cable features a durable thermoplastic elastomer jacket, strain relief, and an e-marker chip, ensuring it withstands the rigors of daily use while maintaining peak performance. Its halogen-free construction and compliance with FCC, RoHS, and USB-IF standards reflect StarTech.com's commitment to quality and environmental responsibility. Whether for work or play, this USB4 cable is the perfect solution for connecting your devices with confidence.
High-speed connectivity
Experience fast data transfer speeds of up to 40 Gbps, enabling quick file transfers, smooth video streaming, and efficient work processes. This USB4 cable is designed to meet the demands of high-bandwidth applications, ensuring a seamless connection between devices. -
Advanced display support
With support for DisplayPort Alternate Mode 1.4, this cable delivers high-resolution video output, enabling 4K at 120Hz and 8K at 60Hz displays. HDR support and Display Stream Compression (DSC) ensure vivid, lifelike images for a high-quality viewing experience. -
Enhanced power delivery
Capable of delivering up to 240 watts of power, this cable supports extended power range (EPR) and Power Delivery 3.1, making it ideal for charging laptops, smartphones, and other devices quickly and efficiently. -
Durable and eco-friendly design
Constructed with a thermoplastic elastomer (TPE) jacket and featuring halogen-free materials, this cable is built for durability while being environmentally friendly. The strain relief design and e-marker chip further enhance its longevity and performance. -
Comprehensive compatibility
Fully compliant with USB4, Thunderbolt 3, Thunderbolt 4, and DisplayPort 1.4 standards, this cable offers versatile connectivity options. Its universal USB-C connectors ensure compatibility with a wide range of devices, from monitors and docking stations to laptops and tablets.
- StarTech.com 50cm (1.6ft) USB4 Cable, USB-IF Certified USB-C Cord 40Gbps - USB-C cable - 24 pin USB-C to 24 pin USB-C - 50 cm
- USB-C cable
- Technology
- Coaxial
- Halogen-free, passive cable, 4K120Hz support, 8K60Hz support, extended power range (EPR), Power Delivery 3.1 support, strain relief, EMI protection, e-marker chip, HDR support, 32 audio channels, High Bit Rate 3 (HBR3), 40 Gbps data rate, Display Stream Compression (DSC), up to 240 Watts of power delivery, DisplayPort Alternate Mode 1.4 support
- Length
- 50 cm
- Connector
- 24 pin USB-C - male
- Connector (Second End)
- Rated Voltage
- 48 V
- Rated Current
- 5 A
- USB4 / Thunderbolt 3 / Thunderbolt 4 / DisplayPort 1.4
- Black
- 2-year warranty
- USB-C cable
- Technology
- Coaxial
- Shielding Material
- Aluminum mylar foil with braid
- Jacket Material
- Thermoplastic elastomer (TPE)
- Rated Voltage
- 48 V
- Rated Current
- 5 A
- Plated Connector
- Nickel
- Length
- 50 cm
- Outside Diameter
- 4.8 mm
- Black
- 23 g
- Connector
- USB4 / Thunderbolt 3 / Thunderbolt 4 / DisplayPort 1.4, FCC, RoHS, USB-IF
- Shipping Width
- 13 cm
- Shipping Depth
- 22 cm
- Shipping Height
- 1 cm
- Shipping Weight
- 30 g
- 2-year warranty
