This Thunderbolt 4 (40 Gbps) cable enables Thunderbolt 4 signals over USB Type-C connectors. Deliver video, data, and up to 100W of Power Delivery to Thunderbolt, USB, and DisplayPort devices.
40 Gbps for Thunderbolt 4 / 3 Devices
This cable supports data transfer of 40 Gbps when connected to a Thunderbolt 4, Thunderbolt 3, or USB4-compatible source and device. It is capable of transferring photo and video files four times faster than standard USB 3.2 gen 2 (10Gbps) cables. -
USB-C Compatible
The Thunderbolt 4 cable is compatible with all USB Type-C devices and can be used to charge and sync mobile devices. In addition, this cable can be used to connect and power USB-C laptops, such as MacBook and Chromebook ; and USB-C peripherals such as portable hard drives and docking stations. -
Full-8K Video
The cable supports full-8K 60Hz video and DisplayPort 1.4a, and is compatible with DisplayPort displays. Use it to connect a docking station to laptop, or a laptop to a display -
USB Power Delivery
This Thunderbolt 4 cable delivers up to 100W of Power Delivery to charge a laptop or power a display, and 15W for bus-powered devices such as hard drive enclosures. -
Thunderbolt Networking
The cable can be used to daisy chain up to 6 Thunderbolt 4 enabled devices, such as laptops for peer-to-peer 10GbE networking. In addition, connect two Thunderbolt 4 laptops to transfer/migrate data.
- StarTech.com 1.6ft (50cm) Thunderbolt 4 Cable, 40Gbps, 100W Power Delivery, 4K/8K Video Support, Intel-Certified Thunderbolt Cable - Compatible w/ USB4/Thunderbolt 3/USB 3.2/USB Type-C/DisplayPort (TBLT4MM50CM) - Thunderbolt cable - Thunderbolt 4 to Thunderbolt 4 - 50 cm
- Thunderbolt cable
- 4K support, 8K support, passive adapter, USB Power Delivery (100W), 40 Gbps data rate, Intel certified
- Length
- 50 cm
- Connector
- Thunderbolt 4 - male
- Connector (Second End)
- USB4/Thunderbolt 3/USB 3.2/USB Type-C/DisplayPort
- Black
- 2-year warranty
- Thunderbolt cable
- Jacket Material
- Thermoplastic elastomer (TPE)
- American Wire Gauge (AWG)
- 30/34
- Plated Connector
- Nickel
- Length
- 50 cm
- Outside Diameter
- 4.6 mm
- Black
- Connector
- USB4/Thunderbolt 3/USB 3.2/USB Type-C/DisplayPort, FCC, RoHS, WEEE, halogen-free
- Shipping Width
- 12.8 cm
- Shipping Depth
- 22 cm
- Shipping Height
- 2 cm
- 2-year warranty
StarTech.com 3ft USB4 Cable, USB-C 40 Gbps | In Stock | £20.69 |
StarTech.com 6ft (2m) Thunderbolt Cable | In Stock | £82.27 |
StarTech.com 1m USB4 Cable, USB-C 40 Gbps | In Stock | £20.51 |
StarTech.com 1.6ft USB4 Cable, USB-C 40Gbps | In Stock | £19.39 |
StarTech.com 3ft (1m) Thunderbolt 5 Cable | In Stock | £32.51 |
StarTech.com 1.5ft/50cm Thunderbolt 5 Cable | In Stock | £29.30 |
StarTech.com 2.6ft/80cm Thunderbolt 5 Cable | In Stock | £30.97 |
StarTech.com 3ft/1m Thunderbolt 5 Cable | In Stock | £32.24 |
StarTech.com 1.5ft/50cm Thunderbolt 5 Cable | In Stock | £30.73 |
StarTech.com 2.6ft/80cm Thunderbolt 5 Cable | In Stock | £32.09 |
