Create Ultra HD connections between your High Speed HDMI-equipped devices over a unique 5 foot connection distance. The HDMM150CM 1.5m High Speed HDMI cable comes in a non-standard 5 foot cable length allowing for a convenient connection distance and enabling you to position your HDMI-enabled devices as needed.
The cable features two gold-plated HDMI male connectors to provide a dependable HDMI to HDMI connection, while the unique cable length makes it perfect for watching videos from your laptop on your HDMI TV or for boardroom presentations when connecting your laptop to an HDMI-enabled projector.
This high quality HDMI cable fully supports 1080p+ resolutions at up to 120Hz refresh rate, with life-like color. To accommodate the demands of future high definition devices, such as increased resolutions and higher frame rates, this Ultra HD cable supports resolutions up to 4k x 2k.
StarTech.com High Speed HDMI digital video and audio cables are expertly designed and constructed of only top quality materials to ensure high quality, high definition performance. The HDMI standard combines high bandwidth video and multi-channel digital audio into a single cable, and provides crystal clear image resolution.
Reliable connection
The cable features double shielded technology which minimizes interference and enhances signal quality for a clear audio and video experience. -
Durable construction
With a PVC jacket and aluminum mylar foil shielding, this HDMI cable is built to endure daily use while maintaining performance integrity. -
Optimized signal quality
Gold-plated connectors provide better conductivity and corrosion resistance, ensuring the connection remains reliable over time. -
Versatile compatibility
This HDMI cable supports Ultra HD 4k x 2k resolutions, making it suitable for high-definition gaming, streaming, and media playback.
- StarTech.com 1.5m High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable - HDMI to HDMI M/M - 5 ft HDMI 1.4 Cable - Audio/Video Gold-Plated (HDMM150CM) - HDMI cable - 1.5 m
- Cable
- HDMI cable
- Technology
- Double shielded
- American Wire Gauge (AWG)
- 28
- Length
- 1.5 m
- Black
- Connector
- HDMI - male
- Connector (Second End)
- HDMI - male
- Limited lifetime warranty
- Designed For
- P/N: MSTCDP122HD
- Cable Type
- HDMI cable
- Technology
- Double shielded
- 28
- Jacket Material
- PVC
- Shielding Material
- Aluminum mylar foil with braid
- Length
- 1.5 m
- Plated Connector
- Gold
- Black
- Connector
- 19 pin HDMI Type A - male
- RoHS
- Limited warranty - lifetime
- Designed For
- P/N: MSTCDP122HD
StarTech.com 10m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M | In Stock | £34.14 |
StarTech.com 3m High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable - HDMI to HDMI M/M | In Stock | £9.65 |
StarTech.com 2m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M | In Stock | £7.48 |
StarTech.com 5m High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable - HDMI to HDMI M/M | In Stock | £13.66 |
StarTech.com 7m High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable - HDMI to HDMI M/M | In Stock | £28.06 |
StarTech.com 1m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M | In Stock | £6.68 |
StarTech.com 0.5m High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable - HDMI to HDMI M/M | In Stock | £6.45 |
