StarTech.com 1.5m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M
Quicklinx: 95F4WS00 Mfr#: HDMM150CM
Length: 1.5m
More than 50 In Stock
£6.78 ex VAT
£8.13 inc VAT
Create Ultra HD connections between your High Speed HDMI-equipped devices over a unique 5 foot connection distance. The HDMM150CM 1.5m High Speed HDMI cable comes in a non-standard 5 foot cable length allowing for a convenient connection distance and enabling you to position your HDMI-enabled devices as needed.
The cable features two gold-plated HDMI male connectors to provide a dependable HDMI to HDMI connection, while the unique cable length makes it perfect for watching videos from your laptop on your HDMI TV or for boardroom presentations when connecting your laptop to an HDMI-enabled projector.
This high quality HDMI cable fully supports 1080p+ resolutions at up to 120Hz refresh rate, with life-like color. To accommodate the demands of future high definition devices, such as increased resolutions and higher frame rates, this Ultra HD cable supports resolutions up to 4k x 2k.
StarTech.com High Speed HDMI digital video and audio cables are expertly designed and constructed of only top quality materials to ensure high quality, high definition performance. The HDMI standard combines high bandwidth video and multi-channel digital audio into a single cable, and provides crystal clear image resolution.
  • Reliable connection
    The cable features double shielded technology which minimizes interference and enhances signal quality for a clear audio and video experience.
  • Durable construction
    With a PVC jacket and aluminum mylar foil shielding, this HDMI cable is built to endure daily use while maintaining performance integrity.
  • Optimized signal quality
    Gold-plated connectors provide better conductivity and corrosion resistance, ensuring the connection remains reliable over time.
  • Versatile compatibility
    This HDMI cable supports Ultra HD 4k x 2k resolutions, making it suitable for high-definition gaming, streaming, and media playback.
Startech 1.5m High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable - HDMI to HDMI M/M - 5 ft HDMI 1.4 Cable - Audio/Video Gold-Plated (HDMM150CM) - HDMI cable - 1.5 m
Cable
HDMI cable
Double shielded
American Wire Gauge (AWG)
28
Cable Length
1.5 m
Connector
HDMI - male
Connector (Second End)
HDMI - male
P/N: MSTCDP122HD
Cable Type
HDMI cable
Double shielded
28
Jacket Material
PVC
Shielding Material
Cable Length
1.5 m
Plated Connector
Gold
Connector
19 pin HDMI Type A - male
RoHS
Limited warranty - lifetime
P/N: MSTCDP122HD
95F4 StarTech.com 10m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £34.49
95F4 StarTech.com 3m High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable - HDMI to HDMI M/M In Stock £9.68
95F4 StarTech.com 2m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £7.74
95F4 StarTech.com 5m High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable - HDMI to HDMI M/M In Stock £14.74
95F4 StarTech.com 7m High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable - HDMI to HDMI M/M In Stock £28.34
95F4 StarTech.com 1m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £6.69
95F4 StarTech.com 0.5m High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable - HDMI to HDMI M/M In Stock £6.31
Length: 1.5m
