StarTech.com 1.5m HDMI to DVI-D Cable - M/M
Quicklinx: 93WPWS00 Mfr#: HDDVIMM150CM
Length: 1.5m
£7.92 ex VAT
£9.50 inc VAT
The HDDVIMM150CM HDMI to DVI-D cable comes in a non-standard 1.5 meter/5 foot cable length allowing for a convenient connection distance and enabling you to position your DVI-D or HDMI-enabled devices as needed.
This bi-directional cable enables you to connect a DVI-D video card to a display that incorporates HDMI technology, or enables you to connect an HDMI-enabled output to a DVI-D capable display.
A valuable addition to any digital signage, multimedia or home theater application, this high-performance cable is designed to provide the best quality picture available through HDMI technology or DVI digital connections.
  • Robust shielding
    The cable features a shielded design with aluminum mylar foil and braid to minimize interference, providing clear and reliable video transmission.
  • Durable connectors
    Molded connectors with strain relief enhance cable durability, preventing wear and tear from frequent usage.
  • High-quality construction
    Constructed with 28 AWG wire and gold-plated connectors, this cable supports high-definition resolutions and stable connections for an optimal viewing experience.
  • Flexible compatibility
    Equipped with a 19-pin HDMI Type-A male connector and an 18+1 pin digital DVI (Single-Link) male connector, this cable easily connects various devices.
  • Environmentally compliant
    This cable meets RoHS compliance standards, ensuring it is environmentally friendly while delivering dependable performance.
StarTech.com 1.5m HDMI to DVID Cable M/M - adapter cable - HDMI / DVI - 1.5 m
Cable
Adapter cable - HDMI / DVI
Shielded
American Wire Gauge (AWG)
28
Length
1.5 m
Connector
DVI-D - male
Connector (Second End)
HDMI - male
Moulded, strain relief
Cable Type
Adapter cable
Interface Supported
HDMI / DVI
Shielded
28
Jacket Material
PVC
Shielding Material
Length
1.5 m
Plated Connector
Gold
Connector
18+1 pin digital DVI (Single-Link) - male
19 pin HDMI Type A - male
RoHS
Limited warranty - lifetime
93WP StarTech.com 2m High Speed HDMI® Cable to DVI Digital Video Monitor In Stock £8.34
93WP StarTech.com 3m HDMI to DVI-D Cable - M/M In Stock £9.63
93WP StarTech.com 5m HDMI to DVI-D Cable – M/M In Stock £9.52
93WP StarTech.com 1m HDMI to DVI-D Cable - M/M In Stock £7.02
93WP StarTech.com 1.5m HDMI to DVI-D Cable - M/M In Stock £7.92
93WP StarTech.com 0.5m HDMI to DVI-D Cable - M/M In Stock £7.58
Length: 1.5m
