StarTech.com 1.5m CAT6a Ethernet Cable LSZH - Blue
Quicklinx: H156WS00 Mfr#: NLBL-150-CAT6A-PATCH
Length: 1.5m
Colour: Blue
£8.62 ex VAT
£10.34 inc VAT
CAT6A ETHERNET CABLE: Ethernet cable for error-free 1/2.5/5/10Gbps multi-gigabit/multi-speed connections - Low proximity crosstalk (NEXT)/return loss (RL) - Meets ANSI/TIA-568.2-D standards - Tested by Fluke and Verified by ETL.
SHIELDED CAT6A CABLE: Enhanced signal and EMI/RFI protection - Individual twisted pairs wrapped in aluminum foil - Outer cover with braided shield - Shielded RJ45 connectors with gold-plated pins.
100W ETHERNET POWER SUPPLY: 100% stranded copper wire provides stable PoE power, unlike copper-clad aluminum versions - Supports PoE devices up to 100W PoE++ - IEEE 802.3bt compliant.
DURABLE LSZH SHEATH: PVC-free, low-smoke, halogen-free (LSZH) cable sheath produces less dense, less corrosive smoke than PVC - Braided FABRICATION resists damage caused by bending.
SPECS: Category 6A network cable - 1.5m - Blue - 10Gbps - 500 MHz - 4 pairs S/FTP - RJ-45 snagless with strain relief - EVA, Al(OH)3 - LSZH - 27 AWG - 100% copper - ETL verified - ANSI/TIA-568.2-D - Supports Cat6 and earlier standards.
  • Efficient data transfer
    This cable supports data rates of up to 10 Gbps, making it suitable for bandwidth-intensive applications. The high-frequency performance of 500 MHz ensures a fast and reliable connection across devices.
  • Safe construction
    Featuring a Low Smoke Zero Halogen (LSZH) jacket, this Ethernet cable reduces harmful emissions in case of fire, making it a safer choice for public spaces and commercial buildings.
  • Effective shielding
    The S/FTP technology helps to reduce electromagnetic interference, providing a stable connection that minimizes packet loss and maximizes signal integrity.
  • Durable design
    Constructed with strain reliefs and molded connectors, this cable is built to withstand everyday use without compromising performance or quality.
  • Reliable compliance
    This cable meets several industry standards including RoHS and IEEE 802.3bt, ensuring that it adheres to environmental guidelines and supports Power over Ethernet applications up to 100 watts.
StarTech.com 1.5m CAT6a Ethernet Cable - Blue - Low Smoke Zero Halogen (LSZH) - 10GbE 500MHz 100W PoE++ Snagless RJ-45 w/Strain Reliefs S/FTP Network Patch Cord - patch cable - 1.5 m - blue
Patch cable - CAT 6a - IEEE 802.3bt
S/FTP
Shielding Material
Foil
Wires per Cable
8 wires
Halogen-free, molded, snagless, stranded, strain relief, minimised Near-End Crosstalk (NEXT), test fluke pass, copper conductor, EMI/RFI protection, 100 Watt maximum input power, reduced Return Loss (RL), damage protection, up to 10 Gbps
Length
1.5 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Blue
Network Cable Type
S/FTP
Shielding Material
Foil
Jacket Material
American Wire Gauge (AWG)
27
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
1.5 m
58.7 g
Blue
Connector
RJ-45 - male
RJ-45 - male
RoHS, ETL, WEEE, ANSI/TIA-568.2-D, PoE++ - up to 500 MHz
Shipping Width
22 cm
Shipping Depth
19 cm
Shipping Height
1.2 cm
Shipping Weight
67.4 g
Length: 1.5m
Colour: Blue
