StarTech.com 1.5m CAT6a Ethernet Cable LSZH - Black
Quicklinx: H14XWS00 Mfr#: NLBK-150-CAT6A-PATCH
Length: 1.5m
Colour: Black
25 In Stock
£8.95 ex VAT
£10.74 inc VAT
CAT6A ETHERNET CABLE: Ethernet cable for error-free 1/2.5/5/10Gbps multi-gigabit/multi-speed connections - Low proximity crosstalk (NEXT)/return loss (RL) - Meets ANSI/TIA-568.2-D standards - Tested by Fluke and Verified by ETL.
SHIELDED CAT6A CABLE: Enhanced signal and EMI/RFI protection - Individual twisted pairs wrapped in aluminum foil - Outer cover with braided shield - Shielded RJ45 connectors with gold-plated pins.
100W ETHERNET POWER SUPPLY: 100% stranded copper wire provides stable PoE power, unlike copper-clad aluminum versions - Supports PoE devices up to 100W PoE++ - IEEE 802.3bt compliant.
DURABLE LSZH SHEATH: PVC-free, low-smoke, halogen-free (LSZH) cable sheath produces less dense, less corrosive smoke than PVC - Braided FABRICATION resists damage caused by bending.
SPECS: Category 6A network cable - 1.5m - Black - 10Gbps - 500 MHz - 4 pairs S/FTP - RJ-45 snagless with strain relief - EVA, Al(OH)3 - LSZH - 27 AWG - 100% copper - ETL verified - ANSI/TIA-568.2-D - Supports Cat6 and earlier standards.
  • Enhanced connectivity
    Equipped with gold-plated RJ-45 connectors, this 1.5m CAT6a Ethernet Cable ensures a high-quality connection that minimizes resistance and maximizes performance, providing reliable, fast data transfer rates up to 10 Gbps.
  • Superior safety
    The Low Smoke Zero Halogen (LSZH) jacket material offers a safer environment by reducing the amount of toxic and corrosive gas emitted during combustion, making it an ideal choice for enclosed spaces.
  • Robust design
    Featuring a snagless design with strain reliefs, this network patch cord is built to withstand the rigors of daily use, ensuring a durable and long-lasting connection. Its molded construction also protects against EMI/RFI interference, preserving signal quality.
  • Advanced performance
    With features like minimized Near-End Crosstalk (NEXT) and reduced Return Loss (RL), this cable is engineered to deliver superior performance, supporting frequencies up to 500 MHz and power over Ethernet (PoE++) up to 100 W.
  • Comprehensive compliance
    Meeting and exceeding various standards including IEEE 802.3bt, ANSI/TIA-568.2-D, ETL, RoHS, and WEEE, this patch cable ensures compatibility and compliance with current industry regulations, ensuring a reliable and secure network connection.
StarTech.com 1.5m CAT6a Ethernet Cable - Black - Low Smoke Zero Halogen (LSZH) - 10GbE 500MHz 100W PoE++ Snagless RJ-45 w/Strain Reliefs S/FTP Network Patch Cord - patch cable - 1.5 m - black
Patch cable - CAT 6a - IEEE 802.3bt
S/FTP
Shielding Material
Foil
Wires per Cable
8 wires
Halogen-free, molded, snagless, stranded, strain relief, minimised Near-End Crosstalk (NEXT), test fluke pass, copper conductor, EMI/RFI protection, 100 Watt maximum input power, reduced Return Loss (RL), damage protection, up to 10 Gbps
Length
1.5 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Network Cable Type
S/FTP
Shielding Material
Foil
Jacket Material
American Wire Gauge (AWG)
27
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
1.5 m
58.7 g
Connector
RJ-45 - male
RJ-45 - male
RoHS, ETL, WEEE, ANSI/TIA-568.2-D, PoE++ - up to 500 MHz
Shipping Width
22 cm
Shipping Depth
19 cm
Shipping Height
1.2 cm
Shipping Weight
67.4 g
Length: 1.5m
Colour: Black
