StarTech.com 1.5m CAT6a Ethernet Cable LSZH - Aqua
Quicklinx: H14JWS00 Mfr#: NLAQ-150-CAT6A-PATCH
Length: 1.5m
Colour: Aqua
£9.02 ex VAT
£10.82 inc VAT
CAT6A ETHERNET CABLE: Ethernet cable for error-free 1/2.5/5/10Gbps multi-gigabit/multi-speed connections - Low proximity crosstalk (NEXT)/return loss (RL) - Meets ANSI/TIA-568.2-D standards - Tested by Fluke and Verified by ETL.
SHIELDED CAT6A CABLE: Enhanced signal and EMI/RFI protection - Individual twisted pairs wrapped in aluminum foil - Outer cover with braided shield - Shielded RJ45 connectors with gold-plated pins.
100W ETHERNET POWER SUPPLY: 100% stranded copper wire provides stable PoE power, unlike copper-clad aluminum versions - Supports PoE devices up to 100W PoE++ - IEEE 802.3bt compliant.
DURABLE LSZH SHEATH: PVC-free, low-smoke, halogen-free (LSZH) cable sheath produces less dense, less corrosive smoke than PVC - Braided FABRICATION resists damage caused by bending.
SPECS: Category 6A network cable - 1.5m - Turquoise - 10Gbps - 500 MHz - 4 pairs S/FTP - RJ-45 snagless with strain relief - EVA, Al(OH)3 - LSZH - 27 AWG - 100% copper - ETL verified - ANSI/TIA-568.2-D - Supports Cat6 and earlier standards.
  • Robust Connectivity
    Equipped with RJ-45 male connectors on both ends, this patch cable ensures a secure and consistent connection in diverse networking setups.
  • Shielding
    The S/FTP technology and foil shielding minimize Near-End Crosstalk (NEXT) and reduce Return Loss (RL), promoting reliable data transmission.
  • Power Capability
    With a maximum input power of 100 watts, the cable supports Power over Ethernet (PoE++) applications for flexible device deployment.
  • Durable Construction
    Featuring a molded and snagless design, the cable is built to resist wear and tear while providing ease of use during installation.
  • Environmentally Compliant
    This cable meets RoHS, WEEE, and ETL standards, ensuring it is environmentally safe and compatible with a range of installations.
StarTech.com 1.5m CAT6a Ethernet Cable - Aqua - Low Smoke Zero Halogen (LSZH) - 10GbE 500MHz 100W PoE++ Snagless RJ-45 w/Strain Reliefs S/FTP Network Patch Cord - patch cable - 1.5 m - aqua
Patch cable - CAT 6a - IEEE 802.3bt
S/FTP
Shielding Material
Foil
Wires per Cable
8 wires
Snagless, stranded, molded, halogen-free, minimised Near-End Crosstalk (NEXT), strain relief, test fluke pass, EMI/RFI protection, up to 10 Gbps, copper conductor, 100 Watt maximum input power, damage protection, reduced Return Loss (RL)
Length
1.5 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Aqua
Network Cable Type
S/FTP
Shielding Material
Foil
Jacket Material
American Wire Gauge (AWG)
27
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
1.5 m
58.7 g
Aqua
Connector
RJ-45 - male
RJ-45 - male
RoHS, WEEE, PoE++, ANSI/TIA-568.2-D, ETL - up to 500 MHz
Shipping Width
22 cm
Shipping Depth
19 cm
Shipping Height
1.2 cm
Shipping Weight
67.4 g
Length: 1.5m
Colour: Aqua
