StarTech.com 1.5m CAT6 Cable - Black Slim CAT6 Patch Cable - Snagless RJ45 Connectors - LSZH
Quicklinx: G6R6WS00 Mfr#: N6PAT150CMBKS
Length: 1.5m
Colour: Black
£4.69 ex VAT
£5.62 inc VAT
Slim CAT6 Patch Cable - Snagless - 28 AWG Copper Wire - LSZH
This slim CAT6 cable meets all Category 6 patch cable specifications to deliver a reliable Gigabit network connection in high-density data center applications.
Easy Cable Runs
The design of this slim CAT6 patch cord is 36% thinner than standard networking cables, which allows better airflow and heat dissipation in tight spaces. The cable is also more flexible than standard Ethernet cables, so cable runs are easier in crowded network racks.
This cable features snagless connectors that protect the RJ45 clips during installation, making them less likely to snag or break as you pull them through narrow spaces.
Protect Your Equipment
This CAT6 patch cable is tested to comply with ANSI/TIA 568 C.2 Category 6 requirements ensuring a reliable connection to your networking equipment. Certified with Low Smoke Zero Halogen (LSZH) fire rating, this patch cord ensures a safe connection.
The 50-micron gold connectors on the patch cable deliver optimum conductivity and eliminate signal loss due to oxidation or corrosion.
High-Quality Construction
Each CAT6 cable is manufactured using high-quality copper conductors and is carefully constructed and tested to keep Near-End Crosstalk (NEXT) well within acceptable limits. Plus, each cable is built with 28 AWG copper wire, to ensure peak performance for your demanding Ethernet applications.
N6PAT150CMBKS is backed by StarTech.com lifetime warranty and free lifetime technical support.
  • Easy Cable Runs
    The design of this slim CAT6 patch cord is 36% thinner than standard networking cables, which allows better airflow and heat dissipation in tight spaces. The cable is also more flexible than standard Ethernet cables, so cable runs are easier in crowded network racks. This cable features snagless connectors that protect the RJ45 clips during installation, making them less likely to snag or break as you pull them through narrow spaces.
  • Protect Your Equipment
    This CAT6 patch cable is tested to comply with ANSI/TIA 568 C.2 Category 6 requirements ensuring a reliable connection to your networking equipment. Certified with Low Smoke Zero Halogen (LSZH) fire rating, this patch cord ensures a safe connection. The 50-micron gold connectors on the patch cable deliver optimum conductivity and eliminate signal loss due to oxidation or corrosion.
  • High-Quality Construction
    Each CAT6 cable is manufactured using high-quality copper conductors and is carefully constructed and tested to keep Near-End Crosstalk (NEXT) well within acceptable limits. Plus, each cable is built with 28 AWG copper wire, to ensure peak performance for your demanding Ethernet applications. N6PAT150CMBKS is backed by StarTech.com lifetime warranty and free lifetime technical support.
StarTech.com 1.5m Slim LSZH CAT6 Ethernet Cable, 10 Gigabit Snagless RJ45 100W PoE Patch Cord, CAT 6 10GbE UTP Network Cable w/Strain Relief, Black, Fluke Tested/ETL/Low Smoke Zero Halogen - Category 6 - 28AWG (N6PAT150CMBKS) - patch cable - 1.5 m - black
Patch cable - CAT 6
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Wires per Cable
8 wires
Snagless, stranded, minimised Near-End Crosstalk (NEXT)
Length
1.5 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Network Cable Type
Patch cable - CAT 6
Wiring Scheme
T568B
Jacket Material
Low Smoke Zero Halogen (LSZH)/PVC
American Wire Gauge (AWG)
28
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
1.5 m
30 g
Connector
RJ-45 - male
RJ-45 - male
RoHS, REACH, ANSI/TIA-568-C.2, TIA/EIA-568-B.1-2001 - up to 250 MHz
G6R6 StarTech.com 1.5m CAT6 Cable - Grey Slim CAT6 Patch Cable - Snagless RJ45 In Stock £5.27
G6R6 StarTech.com 1.5m CAT6 Cable - Blue Slim CAT6 Patch Cable - Snagless RJ45 In Stock £4.69
Length: 1.5m
Colour: Black
