Our thermal CPU paste improves the effectiveness of CPU coolers by thermally bonding the CPU to the heatsink.
A high quality metallic solution that helps to ensure maximum dissipation of heat generated by the CPU for optimized performance and greater system stability; and is more effective than standard silicon-based heat grease/CPU paste, providing optimum protection against CPU heat damage.
The StarTech.com Advantage
- Better thermal conductivity over standard silicon-based compounds and negligible electrical conductivity for effective and safe use in high performance applications
- StarTech.com 1.5g Metal OxIDE Thermal CPU Paste Compound Tube for Heatsink - cpu paste - thermal compound - thermal grease (SILVGREASE1) processor heatsink paste
- Product Type
- Processor heatsink paste
- 1.5 g
- 1-year warranty
- Designed For
- P/N: FAN1156PWM, FAN370PRO, FAN478, FANCSORB, FANDURONTB, FANP1003LD, FANP2SECC
- Product Type
- 1.5 g
- Limited warranty - 1 year
- Designed For
