StarTech.com 1.5g Metal Oxide Thermal CPU Paste Compound Tube for Heatsink
Quicklinx: 76TVWS00 Mfr#: SILVGREASE1
40 In Stock
£4.59 ex VAT
£5.50 inc VAT
Our thermal CPU paste improves the effectiveness of CPU coolers by thermally bonding the CPU to the heatsink.
A high quality metallic solution that helps to ensure maximum dissipation of heat generated by the CPU for optimized performance and greater system stability; and is more effective than standard silicon-based heat grease/CPU paste, providing optimum protection against CPU heat damage.
The StarTech.com Advantage
  • Better thermal conductivity over standard silicon-based compounds and negligible electrical conductivity for effective and safe use in high performance applications
  • Reliable Performance
    This thermal paste, also known as silver grease, is a metal-based compound that contains over 50% metal oxide to offer better thermal conductivity than standard heat transfer pastes. SILVGREASE1 ensures reliable performance in temperatures of -22°F to 365°F (-30°C to 180°C) with thermal conductivity of 3.07 W/m-K at 25 °C or greater. This performance makes the compound ideal for servicing & maintaining workstations, desktop computers and servers, and is best suited for CPUs with TDP of up to 65W
  • Reseable 1.5g Syringe Tubes
    The tube contains 1.5g of paste, sufficient for 4 to 6 applications. the compound is packaged in a syringe for easy application, that's re-sealable to prevent the product from drying between use. SILVGREASE1 is backed by a StarTech.com 2-year warranty, including free lifetime 24/5 multi-lingual, North American based, technical assistance.
StarTech.com Thermal Paste, High Performance Thermal Paste, Re-sealable Syringes (1.5g), Metal Oxide Heat Sink Compound, CPU Thermal Paste, Thermal Glue, RoHS / CE - GPU Grease - processor heatsink paste
Processor heatsink paste
1.5 g
1-year warranty
P/N: FAN1156PWM, FAN370PRO, FAN478, FANCSORB, FANDURONTB, FANP1003LD, FANP2SECC
1.5 g
Limited warranty: - 1 year
76TV StarTech.com Thermal Paste, 5-Pack In Stock £14.44
