StarTech.com 1.5 m CAT6a Cable - Grey- CAT6a STP Cable - Snagless RJ45
Quicklinx: FN5JWS00 Mfr#: 6ASPAT150CMGR
Length: 1.5m
Colour: Grey
10 In Stock
£9.71 ex VAT
£11.65 inc VAT
The shielded Cat6a cables ensure fast and dependable 10 Gigabit network connections by protecting against electromagnetic interference (EMI/RFI) and noise. The result is a fast and safe network.
Each cable is tested for up to 500 MHz frequency and is more than suitable for 10GBase-T Ethernet networks. Plus, the RJ45 connectors are both snagless and molded to prevent damage to the connector clips and the cable. This helps to avoid accidental disconnections and decreases in network performance.
The shielded Cat6a cables help you complete your network solutions, allowing you to organize your cable runs and identify network connections.
  • Durable construction
    The cable features a PVC jacket that ensures long-lasting performance and protection from wear and tear.
  • Effective shielding
    With RFI/EMI shielding, this Ethernet cable minimizes interference, allowing for clearer signals and more reliable connections.
  • High speed capability
    This cable supports frequencies up to 500 MHz, making it suitable for high-speed networking applications.
  • Snagless design
    The snagless design of the connectors prevents damage during installation, ensuring hassle-free connectivity.
  • Compliance with standards
    This cable adheres to RoHS, REACH, and ANSI/TIA-568-C.2 standards, confirming its quality and safety for the environment.
StarTech.com 1.5m CAT6A Ethernet Cable, 10 Gigabit Shielded Snagless RJ45 100W PoE Patch Cord, CAT 6A 10GbE STP Network Cable w/Strain Relief, Grey, Fluke Tested/UL Certified Wiring/TIA - Category 6A - 26AWG (6ASPAT150CMGR) - patch cable - 1.5 m - grey
Patch cable - CAT 6a
Shielded twisted pair (STP)
Shielding Material
Aluminium-polyester foil
Wires per Cable
8 wires
Molded, snagless, RFI/EMI shielding
Length
1.5 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Grey
Network Cable Type
Shielding Material
Jacket Material
PVC
American Wire Gauge (AWG)
26
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Length
1.5 m
67 g
Grey
Connector
RJ-45 - male
RJ-45 - male
RoHS, REACH, ANSI/TIA-568-C.2, CMG - up to 500 MHz
Length: 1.5m
Colour: Grey
