StarTech.com 1.5 m CAT6a Cable - Blue- CAT6a STP Cable - Snagless RJ45
Quicklinx: FN5HWS00 Mfr#: 6ASPAT150CMBL
Length: 1.5m
Colour: Blue
£4.18 ex VAT
£5.01 inc VAT
This shielded Cat6a cable ensures fast and dependable 10 Gigabit network connections by protecting against electromagnetic interference (EMI/RFI) and noise. The result is a fast and safe network.
Each cable is tested for up to 500 MHz frequency and is more than suitable for 10GBase-T Ethernet networks.
Plus, the RJ45 connectors are both snagless and molded to prevent damage to the connector clips and the cable. This helps to avoid accidental disconnections and decreases in network performance.
Available in a variety of lengths and colors, our shielded Cat6a cables help you complete your network solutions, allowing you to organize your cable runs and identify network connections.
  • Reliable performance
    This cable features shielded twisted pairs that provide excellent resistance to RFI and EMI, ensuring a stable connection for sensitive data transfers.
  • High-speed capability
    With a tested frequency of up to 500 MHz, this CAT6A cable supports fast data transmission, suitable for modern networking applications.
  • Durable design
    Constructed with a PVC jacket and molded connectors, this cable is built to withstand regular use, offering longevity and reliable performance.
  • Easy installation
    The snagless design of the connectors prevents damage during installation, allowing for a hassle-free setup of your network.
  • Compliance assurance
    This Ethernet cable adheres to RoHS, REACH, and ANSI/TIA-568-C.2 standards, ensuring it meets industry requirements for safety and performance.
StarTech.com 1.5m CAT6A Ethernet Cable, 10 Gigabit Shielded Snagless RJ45 100W PoE Patch Cord, CAT 6A 10GbE STP Network Cable w/Strain Relief, Blue, Fluke Tested/UL Certified Wiring/TIA - Category 6A - 26AWG (6ASPAT150CMBL) - patch cable - 1.5 m - blue
Patch cable - CAT 6a
Shielded twisted pair (STP)
Shielding Material
Aluminium-polyester foil
Wires per Cable
8 wires
Molded, snagless, RFI/EMI shielding
Length
1.5 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Blue
Network Cable Type
Shielding Material
Jacket Material
PVC
American Wire Gauge (AWG)
26
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Length
1.5 m
67 g
Blue
Connector
RJ-45 - male
RJ-45 - male
RoHS, REACH, ANSI/TIA-568-C.2, CMG - up to 500 MHz
Length: 1.5m
Colour: Blue
