This shielded Cat6a cable ensures fast and dependable 10 Gigabit network connections by protecting against electromagnetic interference (EMI/RFI) and noise. The result is a fast and safe network.
Each cable is tested for up to 500 MHz frequency and is more than suitable for 10GBase-T Ethernet networks.
Plus, the RJ45 connectors are both snagless and molded to prevent damage to the connector clips and the cable. This helps to avoid accidental disconnections and decreases in network performance.
Available in a variety of lengths and colors, our shielded Cat6a cables help you complete your network solutions, allowing you to organize your cable runs and identify network connections.
Reliable performance
This cable features shielded twisted pairs that provide excellent resistance to RFI and EMI, ensuring a stable connection for sensitive data transfers. -
High-speed capability
With a tested frequency of up to 500 MHz, this CAT6A cable supports fast data transmission, suitable for modern networking applications. -
Durable design
Constructed with a PVC jacket and molded connectors, this cable is built to withstand regular use, offering longevity and reliable performance. -
Easy installation
The snagless design of the connectors prevents damage during installation, allowing for a hassle-free setup of your network. -
Compliance assurance
This Ethernet cable adheres to RoHS, REACH, and ANSI/TIA-568-C.2 standards, ensuring it meets industry requirements for safety and performance.
- StarTech.com 1.5m CAT6A Ethernet Cable, 10 Gigabit Shielded Snagless RJ45 100W PoE Patch Cord, CAT 6A 10GbE STP Network Cable w/Strain Relief, Blue, Fluke Tested/UL Certified Wiring/TIA - Category 6A - 26AWG (6ASPAT150CMBL) - patch cable - 1.5 m - blue
- Patch cable - CAT 6a
- Technology
- Shielded twisted pair (STP)
- Shielding Material
- Aluminium-polyester foil
- Wires per Cable
- 8 wires
- Molded, snagless, RFI/EMI shielding
- Length
- 1.5 m
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- Blue
- Limited lifetime warranty
- Network Cable Type
- Technology
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 26
- Wires per Cable
- 8 wires
- Pairs per Cable
- 4 pairs
- Length
- 1.5 m
- 67 g
- Blue
- Connector
- RJ-45 - male
- RJ-45 - male
- RoHS, REACH, ANSI/TIA-568-C.2, CMG - up to 500 MHz
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
FN5H 050978 Condition: Damaged stock - Item is new but has packaging damage outer packaging missing |
£4.17 |
Legend
This part of the stock item is present and in good condition
This part of the stock item is not present or functional
This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard
This item has not been tested.
