100% COPPER WIRING: This Cat6a cable is built with 100% copper wiring to prevent weak power delivery and equipment damage, and features foil-shielded twisted-pair wiring to prevent EMI interference
QUALITY PERFORMANCE: Built for high performance, each CAT6 Ethernet patch cable supports 10GBase-T Ethernet and is tested to comply with?ANSI/TIA 568 C.2 CAT6a requirements
EASY INSTALLATION: The 1.5m network cords feature snagless connectors and molded boots to protect the RJ45 clips from cable damage during installations and to ensure a secure network connection
26 AWG WIRE: All unshielded CAT6 UTP cables are built with 26 AWG wiring to ensure peak performance for your demanding Ethernet applications
THE STARTECH.COM ADVANTAGE: StarTech.com offers a lifetime warranty and free lifetime technical support on this black STP Ethernet cable and has been the IT pro’s choice since 1985
High-performance shielding
The cable is designed with aluminum-polyester foil shielding that protects against radio frequency interference and electromagnetic interference, ensuring reliable data transmission. -
Durable construction
Molded and snagless RJ-45 connectors enhance the durability of the cable while preventing damage to the connectors, making it ideal for frequent plugging and unplugging. -
Wide frequency support
Featuring a tested frequency of up to 500 MHz, this cable supports high-speed network connections, making it suitable for a variety of data-intensive applications. -
Compliance with industry standards
This cable meets various compliance standards, including RoHS and ANSI/TIA-568-C.2, ensuring safety and reliability for users. -
Optimized wire configuration
The cable consists of 8 wires organized into 4 pairs, facilitating effective data transfer while accommodating modern networking requirements.
- StarTech.com 1.5m CAT6A Ethernet Cable, 10 Gigabit Shielded Snagless RJ45 100W PoE Patch Cord, CAT 6A 10GbE STP Network Cable w/Strain Relief, Black, Fluke Tested/UL Certified Wiring/TIA - Category 6A - 26AWG (6ASPAT150CMBK) - patch cable - 1.5 m - black
- Patch cable - CAT 6a
- Technology
- Shielded twisted pair (STP)
- Shielding Material
- Aluminium-polyester foil
- Wires per Cable
- 8 wires
- Molded, snagless, RFI/EMI shielding
- Length
- 1.5 m
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- Black
- Limited lifetime warranty
- Network Cable Type
- Technology
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 26
- Wires per Cable
- 8 wires
- Pairs per Cable
- 4 pairs
- Length
- 1.5 m
- 67 g
- Black
- Connector
- RJ-45 - male
- RJ-45 - male
- RoHS, REACH, ANSI/TIA-568-C.2, CMG - up to 500 MHz
