StarTech.com 1.5 m CAT6a Cable - Black- CAT6a STP Cable - Snagless RJ45
Quicklinx: FN5FWS00 Mfr#: 6ASPAT150CMBK
Length: 1.5m
Colour: Black
£10.22 ex VAT
£12.26 inc VAT
100% COPPER WIRING: This Cat6a cable is built with 100% copper wiring to prevent weak power delivery and equipment damage, and features foil-shielded twisted-pair wiring to prevent EMI interference
QUALITY PERFORMANCE: Built for high performance, each CAT6 Ethernet patch cable supports 10GBase-T Ethernet and is tested to comply with?ANSI/TIA 568 C.2 CAT6a requirements
EASY INSTALLATION: The 1.5m network cords feature snagless connectors and molded boots to protect the RJ45 clips from cable damage during installations and to ensure a secure network connection
26 AWG WIRE: All unshielded CAT6 UTP cables are built with 26 AWG wiring to ensure peak performance for your demanding Ethernet applications
THE STARTECH.COM ADVANTAGE: StarTech.com offers a lifetime warranty and free lifetime technical support on this black STP Ethernet cable and has been the IT pro’s choice since 1985
StarTech.com 1.5m CAT6A Ethernet Cable, 10 Gigabit Shielded Snagless RJ45 100W PoE Patch Cord, CAT 6A 10GbE STP Network Cable w/Strain Relief, Black, Fluke Tested/UL Certified Wiring/TIA - Category 6A - 26AWG (6ASPAT150CMBK) - patch cable - 1.5 m - black
Patch cable - CAT 6a
Shielded twisted pair (STP)
Shielding Material
Aluminium-polyester foil
Wires per Cable
8 wires
Molded, snagless, RFI/EMI shielding
Length
1.5 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Network Cable Type
Shielding Material
Jacket Material
PVC
American Wire Gauge (AWG)
26
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Length
1.5 m
67 g
Connector
RJ-45 - male
RJ-45 - male
RoHS, REACH, ANSI/TIA-568-C.2, CMG - up to 500 MHz
Length: 1.5m
Colour: Black
