StarTech.com 1.5 m CAT6a Cable - Black- CAT6a STP Cable - Snagless RJ45
Quicklinx: FN5FWS00 Mfr#: 6ASPAT150CMBK
Length: 1.5m
Colour: Black
29 In Stock
£9.69 ex VAT
£11.62 inc VAT
100% COPPER WIRING: This Cat6a cable is built with 100% copper wiring to prevent weak power delivery and equipment damage, and features foil-shielded twisted-pair wiring to prevent EMI interference
QUALITY PERFORMANCE: Built for high performance, each CAT6 Ethernet patch cable supports 10GBase-T Ethernet and is tested to comply with?ANSI/TIA 568 C.2 CAT6a requirements
EASY INSTALLATION: The 1.5m network cords feature snagless connectors and molded boots to protect the RJ45 clips from cable damage during installations and to ensure a secure network connection
26 AWG WIRE: All unshielded CAT6 UTP cables are built with 26 AWG wiring to ensure peak performance for your demanding Ethernet applications
THE STARTECH.COM ADVANTAGE: StarTech.com offers a lifetime warranty and free lifetime technical support on this black STP Ethernet cable and has been the IT pro’s choice since 1985
  • High-performance shielding
    The cable is designed with aluminum-polyester foil shielding that protects against radio frequency interference and electromagnetic interference, ensuring reliable data transmission.
  • Durable construction
    Molded and snagless RJ-45 connectors enhance the durability of the cable while preventing damage to the connectors, making it ideal for frequent plugging and unplugging.
  • Wide frequency support
    Featuring a tested frequency of up to 500 MHz, this cable supports high-speed network connections, making it suitable for a variety of data-intensive applications.
  • Compliance with industry standards
    This cable meets various compliance standards, including RoHS and ANSI/TIA-568-C.2, ensuring safety and reliability for users.
  • Optimized wire configuration
    The cable consists of 8 wires organized into 4 pairs, facilitating effective data transfer while accommodating modern networking requirements.
StarTech.com 1.5m CAT6A Ethernet Cable, 10 Gigabit Shielded Snagless RJ45 100W PoE Patch Cord, CAT 6A 10GbE STP Network Cable w/Strain Relief, Black, Fluke Tested/UL Certified Wiring/TIA - Category 6A - 26AWG (6ASPAT150CMBK) - patch cable - 1.5 m - black
Patch cable - CAT 6a
Shielded twisted pair (STP)
Shielding Material
Aluminium-polyester foil
Wires per Cable
8 wires
Molded, snagless, RFI/EMI shielding
Length
1.5 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Network Cable Type
Shielding Material
Jacket Material
PVC
American Wire Gauge (AWG)
26
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Length
1.5 m
67 g
Connector
RJ-45 - male
RJ-45 - male
RoHS, REACH, ANSI/TIA-568-C.2, CMG - up to 500 MHz
Length: 1.5m
Colour: Black
