StarTech.com 0.8m / 2.7ft Thunderbolt 3 to Thunderbolt 3 Cable - 40Gbps
Quicklinx: FC02WS00 Mfr#: TBLT34MM80CM
Length: 80cm
More than 50 in stock
£30.04 ex VAT
£36.04 inc VAT
This Thunderbolt 3 to Thunderbolt 3 cable lets you deliver video, data and power to your Thunderbolt 3, USB 3.2 and DisplayPort devices. At 0.8 meters in length, the Thunderbolt cable provides added flexibility and distance when connected to your devices.
Fully compatible with your USB 3.2 Gen 2 devices, this cable can be used for charging and syncing your mobile devices. Also, connect and power USB-C laptops, such as your MacBook or Chromebook, and USB-C peripherals, such as your docking station.
This Thunderbolt 3 USB-C cable supports data transfer rates up to 40Gbps when connected to a Thunderbolt 3 device, enabling lightning fast performance. When connected to a USB 3.2 device, this cable supports rates of 20Gbps.
This cable supports dual 4K 60Hz or full 5K 60Hz video for an astonishing resolution, contrast, and color depth.
The Thunderbolt 3 Type-C cable delivers up to 100W of power for charging a Thunderbolt 3 laptop, which means you can keep your devices powered without using an additional power supply.
Bridge multiple Thunderbolt 3 USB-C enabled laptops for peer-to-peer 10GbE networking with this cable. It's also perfect for sharing peripherals such as printers and storage.
StarTech.com 0.8m/2.7ft Thunderbolt 3 to Thunderbolt 3 Cable - 40Gbps - Certified TB3 - USB C Compatible - Active - 100W PD (TBLT34MM80CM) - Thunderbolt cable - USB-C to USB-C - 80 cm
Thunderbolt cable
Shielded
4K support, 5K support, Power Delivery (PD) technology
Length
80 cm
Connector
24 pin USB-C - male
Connector (Second End)
24 pin USB-C - male
Thunderbolt 3 / USB / DisplayPort
P/N: PEXUSB321C
Thunderbolt cable
Shielded
Shielding Material
Jacket Material
PVC
Plated Connector
Nickel
Length
80 cm
25 g
Connector
24 pin USB-C - male
24 pin USB-C - male
Thunderbolt 3 / USB / DisplayPort, RoHS, WEEE, REACH
Shipping Width
12.5 cm
Shipping Depth
2.5 cm
Shipping Height
22 cm
P/N: PEXUSB321C
FC02 StarTech.com 2m Thunderbolt 3 20Gbps Cable In Stock £30.43
FC02 StarTech.com 1m Thunderbolt 3 20Gbps Cable In Stock £24.29
FC02 StarTech.com 0.5m Thunderbolt 3 Cable In Stock £20.07
FC02 StarTech.com 1m Thunderbolt 3 40Gbps Cable In Stock £60.21
FC02 StarTech.com 0.5m Thunderbolt 3 Cable White In Stock £20.01
FC02 StarTech.com 0.8m / 2.7ft Thunderbolt 3 to Thunderbolt 3 Cable - 40Gbps In Stock £30.04
Length: 80cm
Stock Status: In stock
