This Thunderbolt 3 to Thunderbolt 3 cable lets you deliver video, data and power to your Thunderbolt 3, USB 3.2 and DisplayPort devices. At 0.8 meters in length, the Thunderbolt cable provides added flexibility and distance when connected to your devices.
Fully compatible with your USB 3.2 Gen 2 devices, this cable can be used for charging and syncing your mobile devices. Also, connect and power USB-C laptops, such as your MacBook or Chromebook, and USB-C peripherals, such as your docking station.
This Thunderbolt 3 USB-C cable supports data transfer rates up to 40Gbps when connected to a Thunderbolt 3 device, enabling lightning fast performance. When connected to a USB 3.2 device, this cable supports rates of 20Gbps.
This cable supports dual 4K 60Hz or full 5K 60Hz video for an astonishing resolution, contrast, and color depth.
The Thunderbolt 3 Type-C cable delivers up to 100W of power for charging a Thunderbolt 3 laptop, which means you can keep your devices powered without using an additional power supply.
Bridge multiple Thunderbolt 3 USB-C enabled laptops for peer-to-peer 10GbE networking with this cable. It's also perfect for sharing peripherals such as printers and storage.
USB-C Compatibility
Fully compatible with your USB 3.2 Gen 2 devices, this cable can be used for charging and syncing your mobile devices. Also, connect and power USB-C laptops, such as your MacBook or Chromebook, and USB-C peripherals, such as your docking station. -
Unbelievable Data Transfer Speeds
This Thunderbolt 3 USB-C cable supports data transfer rates up to 40Gbps when connected to a Thunderbolt 3 device, enabling lightning fast performance. When connected to a USB 3.2 device, this cable supports rates of 20Gbps. -
Enjoy?Ultra High Definition Video
This cable supports?dual 4K 60Hz or full 5K 60Hz video for an astonishing resolution, contrast, and color depth. -
Versatile Power Delivery
The Thunderbolt 3 Type-C cable delivers up to 100W of power for charging a Thunderbolt 3 laptop, which means you can keep your devices powered without using an additional power supply. -
Enable Thunderbolt Networking
Bridge multiple Thunderbolt 3 USB-C enabled laptops for peer-to-peer 10GbE networking with this cable. It's also perfect for sharing peripherals such as printers and storage. TBLT34MM80CM is backed by a StarTech.com 2-year warranty and free lifetime technical support.
- StarTech.com 2.6ft (80cm) Thunderbolt 3 Cable, 40Gbps, 100W PD, 4K/5K Video, Thunderbolt-Certified, Compatible w/ TB4/USB 3.2/DisplayPort - Thunderbolt cable - 24 pin USB-C to 24 pin USB-C - 80 cm
- Thunderbolt cable
- Technology
- Shielded
- 4K support, 5K support, Power Delivery (PD) technology
- Length
- 80 cm
- Connector
- 24 pin USB-C - male
- Connector (Second End)
- Thunderbolt 3 / USB / DisplayPort
- Black
- 2-year warranty
- Designed For
- P/N: PEXUSB321C
- Thunderbolt cable
- Technology
- Shielded
- Shielding Material
- Aluminum mylar foil with braid
- Jacket Material
- PVC
- Plated Connector
- Nickel
- Length
- 80 cm
- Black
- 25 g
- Connector
- Thunderbolt 3 / USB / DisplayPort, RoHS, WEEE, REACH
- Shipping Width
- 12.5 cm
- Shipping Depth
- 2.5 cm
- Shipping Height
- 22 cm
- 2-year warranty
- Designed For
- P/N: PEXUSB321C
StarTech.com 2m Thunderbolt 3 20Gbps Cable | In Stock | £39.14 |
StarTech.com 1m Thunderbolt 3 20Gbps Cable | In Stock | £32.70 |
StarTech.com 0.5m Thunderbolt 3 Cable | In Stock | £19.40 |
StarTech.com 1m Thunderbolt 3 40Gbps Cable | In Stock | £62.81 |
StarTech.com 0.5m Thunderbolt 3 Cable White | In Stock | £28.43 |
StarTech.com 1m Thunderbolt 3 Cable White | In Stock | £32.31 |
StarTech.com 2m Thunderbolt 3 Cable White | In Stock | £39.20 |
StarTech.com 0.8m / 2.7ft Thunderbolt 3 to Thunderbolt 3 Cable - 40Gbps | In Stock | £31.44 |
