Product
StarTech.com 0.6m (2ft) Coiled Black Apple 8-pin Lightning Connector to USB Cable iPhone iPod iPad
Quicklinx: 93FKWS00 Mfr#: USBCLT60CMB
Length: 60cm
Colours:
More than 50 in stock
£11.10 ex VAT
£13.32 inc VAT
Charge your Apple Lightning-equipped devices with reduced clutter, in your car with this 2ft coiled cable. The USBCLT60CMB Black Coiled Lightning to USB Cable for iPhone, iPod, and iPad can comfortably be stretched out to up to 0.6m/2ft to reach your mobile device and when compressed can be tucked out of the way to provide simple, tidy connections - great for charging in your car (requires USB charge port).
Colored to suit your black mobile devices, this Lightning to USB cable provides a reliable solution for both syncing and charging and provides a compact solution that makes it perfect for carrying as an iPad or iPhone accessory.
Plus, the reversible 8-pin Lightning connector can be plugged into your iOS-enabled device with either side facing up, meaning there is no wrong way of inserting the cable into the device.
This durable cable is Apple MFi certified.
StarTech.com Coiled Black Apple Lightning to USB Cable for iPhone iPod iPad - Lightning cable - Lightning / USB - 60 cm
Cable
Shielded
American Wire Gauge (AWG)
24/28
Length
60 cm
Connector
Lightning - male
Connector (Second End)
USB - male
Coiled
2 years warranty
Apple iPad mini; iPad with Retina display (4th generation); iPhone 5, 5c, 5s; iPod nano (7G); iPod touch (5G)
Cable Type
Lightning cable
Interface Supported
Lightning / USB
Shielded
24/28
Jacket Material
PVC
Shielding Material
Length
60 cm
Plated Connector
Nickel
Coiled
Connector
Apple Lightning - male
4 pin USB Type A - male
RoHS
Apple iPad mini , Apple iPad with Retina display (4th generation) , Apple iPhone 5, 5c, 5s , Apple iPod nano (7G) , Apple iPod touch (5G)
Length: 60cm
Price Range Ex VAT: 0 - 50
