SATA Data Cable Straight Latching Connectors 6Gbps Lifetime Warranty. This 0.6 m round SATA cable provides a secure connection to your SATA drives while ensuring optimal airflow throughout your desktop or server case.
Improved Airflow
Featuring a rounded design, this SATA hard drive power cable helps improve airflow inside your computer. It provides less resistance as air passes around the SATA cable ensuring cooling for optimized system performance.
Secure Connection
The latching SATA cable features locking connectors that help prevent accidental disconnections when connected to your SATA drives.
Fast Transfer Rates
Compliant with SATA 6Gb/s specifications, this SATA cord supports fast data transfer rates of up to 6Gbps when used with SATA 3.0 compliant drives.
Comprehensive Product Testing & Expert Technical Support
StarTech.com conducts thorough compatibility and performance testing on all our products to ensure we are meeting or exceeding industry standards and providing high-quality products to our customers. Our local StarTech.com Technical Advisors have a broad product expertise and work directly with StarTech.com Engineers to provide support for our customers both pre and post-sales.
SATRD60CM is backed by a StarTech.com lifetime warranty and free lifetime technical support.
Improved airflow
Featuring a rounded design, this SATA hard drive power cable helps improve airflow inside your computer. It provides less resistance as air passes around the SATA cable ensuring cooling for optimized system performance. -
Secure connection
The latching SATA cable features locking connectors that help prevent accidental disconnections when connected to your SATA drives. -
Fast transfer rates
- StarTech.com 0.6 m Round SATA Cable - Latching Connectors - 6Gbs SATA Cable - SATA cable - 60 cm
- SATA cable
- Interface Speed
- Serial ATA 150/300/600
- Round
- Length
- 60 cm
- Connector
- 7 pin Serial ATA - receptacle - latched
- Connector (Second End)
- Black
- Limited lifetime warranty
- Storage Cable Type
- SATA cable
- Interface Speed
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 30
- Round
- Length
- 60 cm
- Black
- 1.41 cm
- 0.65 cm
- 75 g
- Connector
- RoHS, WEEE, REACH
- Shipping Width
- 12.8 cm
- Shipping Depth
- 22.9 cm
- Shipping Weight
- 80 g
