StarTech.com 0.5m Yellow Cat6 Patch Cable
Quicklinx: CNDDWS00 Mfr#: N6PATC50CMYL
Length: 50cm
Colour: Yellow
£3.76 ex VAT
£4.51 inc VAT
0.5m Yellow Cat6 Ethernet Patch Cable with Snagless RJ45 Connectors
  • 100% copper for outstanding value
    Get the highest value for your cable investment with the Cat 6 cables, each one manufactured using high-quality copper conductors.
  • 24-gauge wire for high-performance network connections
  • 50-micron gold connectors provide peak conductivity
    Rely on the RJ45 connectors to deliver optimum conductivity while eliminating signal loss due to oxidation or corrosion.
StarTech.com 50cm CAT6 Ethernet Cable, 10 Gigabit Snagless RJ45 650MHz 100W PoE Patch Cord, CAT 6 10GbE UTP Network Cable w/Strain Relief, Yellow, Fluke Tested/Wiring is UL Certified/TIA - Category 6 - 24AWG (N6PATC50CMYL) - network cable - 50 cm - yellow
Network cable - CAT 6
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Wires per Cable
8 wires
Snagless, stranded, PoE ready
Length
50 cm
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Yellow
Network Cable Type
Wiring Scheme
T568B
Jacket Material
PVC
American Wire Gauge (AWG)
24
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
50 cm
26 g
Yellow
Connector
RJ-45 - male
RJ-45 - male
RoHS, ETL, WEEE - up to 500 MHz
CNDD StarTech.com 0.5m Blue Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £3.63
CNDD StarTech.com 0.5m Black Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £3.63
CNDD StarTech.com 0.5m Gray Cat6 Patch Cable In Stock £3.62
CNDD StarTech.com 0.5m Green Cat6 Patch Cable In Stock £3.63
CNDD StarTech.com 0.5m Orange Cat6 Patch Cable In Stock £3.55
CNDD StarTech.com 0.5m Purple Cat6 Patch Cable In Stock £3.76
CNDD StarTech.com 0.5m Red Cat6 Patch Cable In Stock £3.63
CNDD StarTech.com 0.5m White Cat6 Patch Cable In Stock £3.63
Length: 50cm
Colour: Yellow
