100% copper for outstanding value
Get the highest value for your cable investment with the Cat 6 cables, each one manufactured using high-quality copper conductors. -
24-gauge wire for high-performance network connections
Ensure high-performance capability for your demanding Ethernet applications, such as Power-over-Ethernet, using cables that include 24 AWG copper. -
50-micron gold connectors provide peak conductivity
Rely on the RJ45 connectors to deliver optimum conductivity while eliminating signal loss due to oxidation or corrosion.
- StarTech.com 50cm CAT6 Ethernet Cable, 10 Gigabit Snagless RJ45 650MHz 100W PoE Patch Cord, CAT 6 10GbE UTP Network Cable w/Strain Relief, Yellow, Fluke Tested/Wiring is UL Certified/TIA - Category 6 - 24AWG (N6PATC50CMYL) - network cable - 50 cm - yellow
- Network cable - CAT 6
- Technology
- Wiring Scheme
- T568B
- Wires per Cable
- 8 wires
- Snagless, stranded, PoE ready
- Length
- 50 cm
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- Yellow
- Limited lifetime warranty
- Network Cable Type
- Technology
- Wiring Scheme
- T568B
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 24
- Wires per Cable
- 8 wires
- Pairs per Cable
- 4 pairs
- Plated Connector
- Gold
- Length
- 50 cm
- 26 g
- Yellow
- Connector
- RJ-45 - male
- RJ-45 - male
- RoHS, ETL, WEEE - up to 500 MHz
StarTech.com 0.5m Blue Gigabit Snagless RJ45 UTP Cat6 Patch Cable | In Stock | £4.38 |
StarTech.com 0.5m Black Gigabit Snagless RJ45 UTP Cat6 Patch Cable | In Stock | £4.38 |
StarTech.com 0.5m Gray Cat6 Patch Cable | In Stock | £4.87 |
StarTech.com 0.5m Green Cat6 Patch Cable | In Stock | £4.38 |
StarTech.com 0.5m Orange Cat6 Patch Cable | In Stock | £4.28 |
StarTech.com 0.5m Purple Cat6 Patch Cable | In Stock | £4.87 |
StarTech.com 0.5m Red Cat6 Patch Cable | In Stock | £4.28 |
StarTech.com 0.5m White Cat6 Patch Cable | In Stock | £4.38 |
