StarTech.com 0.5m Yellow Cat5e Patch Cable
Quicklinx: CRFRWS00 Mfr#: 45PAT50CMYL
Length: 50cm
Colour: Yellow
Hurry, only 1 left in stock!
£3.77 ex VAT
£4.52 inc VAT
The wide selection of Cat 5e patch cables makes it easy to find the lengths and colors that you need to complete your network connections.
These Ethernet cables are:
  • Durable. All of the patch cables are constructed to the highest industry standards, to ensure high-quality installs.
  • Dependable. You can rely on these Cat 5e cables to deliver the stability and speed that you need for reliable network performance.
  • Backed by a lifetime manufacturer warranty. All of these network cables are guaranteed to last as long as you need them.
  • Find the length and color you need
    This 0.5-meter yellow network cable is perfect for use in server closets, patch panels and with Ethernet hubs. The cable is intended for short-distance applications such as point-to-point in-rack and across-rack network switch and server connections. For easier network installations, our Cat 5e cables are available in a wide variety of lengths and colors. This ensures you have the right size of cable available when you need it and it lets you color code your connections for a more organized setup.
  • Snagless RJ45 clips help protect your network connections
    For trouble-free cable runs, this durable cable features snagless connectors that protect the RJ45 clips during installation, making them less likely to snag or break. The cable also features moulded boots which offer connector strain relief by stopping the RJ45 connector termination points from bending at sharp angles. This reduces the risk of damage to the cable, which could decrease network connectivity and performance.
  • 100% copper for outstanding value
    Get the highest value for your cable investment with our Cat5e Ethernet cables, each one manufactured using high-quality copper conductors. They are carefully constructed and tested, to keep Near-End Crosstalk (NEXT) well within acceptable limits.
  • 24-gauge wire for high-performance network connection
    Ensure high-performance capability for your demanding Ethernet applications, such as Power-over-Ethernet and 4K or 1080p video streaming, using cables that include 24 AWG copper.
  • 50-micron gold connectors provide peak conductivity
    You can rely on our RJ45 connectors to deliver optimum conductivity, while eliminating signal loss due to oxidation or corrosion. The 45PAT50CMYL is backed by StarTech.com's lifetime warranty for guaranteed reliability.
StarTech.com 0.5m Yellow Cat5e / Cat 5 Snagless Ethernet Patch Cable 0.5 m - patch cable - 50 cm - yellow
Patch cable - CAT 5e
Unshielded twisted pair (UTP)
Snagless, stranded, PoE ready
Length
50 cm
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Yellow
Network Cable Type
Jacket Material
PVC
American Wire Gauge (AWG)
24
Plated Connector
Copper
Length
50 cm
26 g
Yellow
Connector
RJ-45 - male
RJ-45 - male
Up to 350 MHz
CRFR StarTech.com 0.5m Blue Cat5e Patch Cable In Stock £3.98
CRFR StarTech.com 0.5m Green Cat5e Patch Cable In Stock £2.44
CRFR StarTech.com 0.5m Red Cat5e Patch Cable In Stock £2.44
CRFR StarTech.com 0.5m White Cat5e Patch Cable In Stock £3.96
CRFR StarTech.com 0.5m Yellow Cat5e Patch Cable In Stock £3.77
CRFR StarTech.com 0.5m Gray Cat5e Patch Cable In Stock £3.96
CRFR StarTech.com 0.5m Orange Cat5e Patch Cable In Stock £2.44
CRFR StarTech.com 0.5m Black Cat5e Patch Cable In Stock £3.77
Length: 50cm
Colour: Yellow
