Charge or sync your portable Micro USB 2.0 devices at shorter distances, with this lightweight white cable. The USBPAUB50CMW 0.5m White USB to Micro USB Cable features thin USB connector moldings and provides a simpler connection between your Micro USB 2.0 mobile devices (smartphones, digital cameras, Tablet PC devices, portable hard drives, etc.) and your PC or Mac computer, for everyday tasks such as charging, data synchronization or file transfers.
Perfect for close-range device connections, shorter micro USB cables provide a portable solution that makes them perfect for carrying as a tablet or laptop accessory.
- StarTech.com 0.5m White Micro USB Cable Cord - A to Micro B - Micro USB Charging Data Cable - USB 2.0 - 1x USB A Male, 1x USB Micro B Male (USBPAUB50CMW) - USB cable - Micro-USB Type B to USB - 0.5 m
- USB cable
- Technology
- Double shielded
- Molded, strain relief
- Length
- 0.5 m
- Connector
- 5 pin Micro-USB Type B - male
- Connector (Second End)
- 4 pin USB Type A - male
- USB / USB 2.0
- White
- Limited lifetime warranty
- Designed For
- P/N: HB30C4AFS, USB3SMDOCK4K, USBEXTPAA1MW, USBEXTPAA2MW, USBEXTPAA3MW, USBPAUB1MW, USBPAUB2MW
- USB cable
- Technology
- Double shielded
- American Wire Gauge (AWG)
- 28
- Plated Connector
- Nickel
- Length
- 0.5 m
- White
- Connector
- USB / USB 2.0, RoHS
- Designed For
StarTech.com 3m White USB 2.0 Extension Cable A to A - M/F | In Stock | £6.37 |
StarTech.com 1m White USB 2.0 Extension Cable A to A - M/F | In Stock | £5.51 |
StarTech.com 0.5m White Micro USB Cable - A to Micro B | In Stock | £5.13 |
