StarTech.com N6PATC50CMWH. Cable length: 0.5 m, Cable standard: Cat6, Connector 1: RJ-45. Weight: 26 g. Package width: 200 mm, Package depth: 220 mm, Package height: 10 mm
Reliable performance
This cable features gold-plated connectors that enhance conductivity and reduce the risk of corrosion, ensuring a stable connection for data transmission. -
Enhanced durability
The PVC jacket protects the internal wiring from physical damage while maintaining flexibility and ease of routing in tight spaces. -
Efficient wiring scheme
The T568B wiring scheme provides consistent performance and maintains network reliability across different environments. -
Flexible installation options
This 50 cm cable length offers flexibility for various networking setups, whether at home or in an office, catering to a range of distances and configurations.
- Startech 50cm CAT6 Ethernet Cable, 10 Gigabit Snagless RJ45 650MHz 100W PoE Patch Cord, CAT 6 10GbE UTP Network Cable w/Strain Relief, White, Wiring is UL Certified/TIA - Category 6 - 24AWG (N6PATC50CMWH) - network cable - 50 cm - white
- Network cable - CAT 6
- Technology
- Wiring Scheme
- T568B
- Wires per Cable
- 8 wires
- Molded, snagless, stranded, strain relief, PoE ready
- Cable Length
- 50 cm
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- White
- Limited lifetime warranty
- Network Cable Type
- Technology
- Wiring Scheme
- T568B
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 24
- Wires per Cable
- 8 wires
- Pairs per Cable
- 4 pairs
- Plated Connector
- Gold
- Cable Length
- 50 cm
- 26 g
- White
- Connector
- RJ-45 - male
- RJ-45 - male
- RoHS, ETL, TIA/EIA-568-B - up to 500 MHz
StarTech.com 0.5m Blue Gigabit Snagless RJ45 UTP Cat6 Patch Cable | In Stock | £3.70 |
StarTech.com 0.5m Black Gigabit Snagless RJ45 UTP Cat6 Patch Cable | In Stock | £3.59 |
StarTech.com 0.5m Gray Cat6 Patch Cable | In Stock | £3.70 |
StarTech.com 0.5m Green Cat6 Patch Cable | In Stock | £3.70 |
StarTech.com 0.5m Orange Cat6 Patch Cable | In Stock | £3.70 |
StarTech.com 0.5m Purple Cat6 Patch Cable | In Stock | £3.70 |
StarTech.com 0.5m Red Cat6 Patch Cable | In Stock | £3.70 |
StarTech.com 0.5m White Cat6 Patch Cable | In Stock | £3.59 |
StarTech.com 0.5m Yellow Cat6 Patch Cable | In Stock | £3.70 |
