StarTech.com 0.5m USB C Cable - USB 3.1
Quicklinx: D4FJWS00 Mfr#: USB31CC50CM
Length: 50cm
24 In Stock
£12.46 ex VAT
£14.95 inc VAT
Connect your USB Type-C devices, with reduced clutter. This USB-C to USB-C cable lets you connect a USB 3.1, USB Type-C device, such as a hard drive or mobile device, to the USB-C port on your computer, charger or tablet. The cable is also compatible with Thunderbolt 3 ports.
This 0.5-meter cable is great for close-range connections to charge and sync your mobile devices with your laptop. Moving large files or transferring movies can be done in seconds, at twice the speed of USB 3.0 and 20x faster than USB 2.0 - all while charging your device with 60 watts (3 amps) power delivery.
You can also use the cable to charge your devices from a USB-C wall charger, car charger or power bank - perfect for people on the move, for providing simple, tidy connections.
The short cable lets you set up in small offsite workspaces, or in a coffee shop or hotel room. It lets you connect a USB 3.1 peripheral device, such as your external hard drive to your laptop, without excess cable getting in your way.
With a bandwidth of 10Gbps, this USB 3.1 Gen 2 cable lets you sync your USB Type-C devices in no time at all. You can spend less time transferring and backing up your data and more time focusing on your projects and presentations.
The cable supports full 4K 60Hz video and DisplayPort 1.2 and is compatible with existing DisplayPort displays. It's ideal for connecting your docking station or laptop to a monitor with astonishing resolution, contrast, and color depth, for amazing detail.
StarTech.com USB C to UCB C Cable - 0.5m - Short - M/M - USB 3.1 (10Gbps) - USB C Charging Cable - USB Type C Cable - USB-C to USB-C Cable (USB31CC50CM) - USB-C cable - 24 pin USB-C to 24 pin USB-C - 50 cm
USB-C cable
Double shielded
4K support, Power Delivery (PD) technology, 10 Gbps data rate
Length
50 cm
Connector
24 pin USB-C - male - straight
Connector (Second End)
USB 3.1 Gen 2 / Thunderbolt 3 / DisplayPort 1.2
P/N: 4SD4FCRU31C, HB31C2A1CGB, HB31C2A1CGS, HB31C2A2CB, HB31C3A1CB, HB31C3A1CPD3, HB31C3A1CS, HB31C3ASDMB, HB31C4AS, M2E1BMU31C, M2E1BRU31C, PEXUSB311AC3, S251BRU31C3, SDOCK4U313, SV211HDUC, SV221HUC4K, TB33A1C
USB-C cable
Double shielded
Shielding Material
Jacket Material
PVC
American Wire Gauge (AWG)
26/32
Length
50 cm
26 g
Connector
D4FJ StarTech.com 1m 3ft USB 3.1 USB-C Cable M/M In Stock £13.22
D4FJ StarTech.com 2m USB 3.0 C Cable w/ PD (3A) In Stock £14.34
D4FJ StarTech.com 0.5m USB C Cable - USB 3.1 In Stock £12.46
Length: 50cm
