Connect USB Micro-B devices to your USB Type-C host with reduced clutter. This USB-C to Micro-B cable lets you connect your USB 3.1 (10Gbps) Micro-USB devices to your USB Type-C laptop. You can also charge and sync your USB 3.0 (5Gbps) Micro-USB mobile devices.
This non-standard 0.5-meter cable is great for close-range connections from your USB-C laptop to a USB 3.1 drive enclosure, dock or other Micro-USB device, wherever you go.
The short cable lets you set up your equipment without excess cable getting in your way. It's extremely portable, which is perfect for connections in small offsite workspaces or in a coffee shop or hotel room.
With a bandwidth of 10Gbps, this USB 3.1 Gen 2 cable lets you transfer and back up data at twice the speed of USB 3.0 and 20x faster than USB 2.0. You can also connect older USB 3.0 peripheral devices to newer computers, with data transfer speeds of up to 5Gbps.
Connect your Micro-USB 3.0 phone or tablet to your USB 3.1 laptop or desktop computer, for syncing and charging.
                Efficient data transferWith a data rate of 10 Gbps, this USB-C to Micro-USB cable ensures quick and efficient transfer of files and resources, making it ideal for personal and professional use.
                Versatile compatibilityFeaturing a 24-pin USB-C connector and a 10-pin Micro-USB Type-B connector, this cable is compatible with a variety of devices, enhancing its usability across different platforms.
                Robust constructionThe cable's aluminum mylar foil with braid shielding reduces signal interference, providing improved performance and reliability during data transmission.
                Durable designThe PVC jacket contributes to the cable's longevity, making it resistant to wear and tear, suitable for daily usage and travel.
                Eco-friendly complianceRoHS and WEEE compliance demonstrates a commitment to reducing environmental impact through sustainable materials in this cable's construction.
- StarTech.com USB C to Micro USB Cable 0.5m - USB 3.1 Type C to Micro USB Type B Cable - Micro USB 3.1 to USB-C - Thunderbolt 3 Compatible (USB31CUB50CM) - USB-C cable - 24 pin USB-C to Micro-USB Type B - 50 cm
- USB-C cable
- Technology
- Shielded
- 10 Gbps data rate
- Length
- 50 cm
- Connector
- 24 pin USB-C - male
- Connector (Second End)
- 10 pin Micro-USB Type B - male
- USB 3.1 Gen 2
- Black
- 2-year warranty
- Designed For
- P/N: HB31C2A1CGB, HB31C2A1CGS, HB31C2A2CB, HB31C3A1CB, HB31C3A1CPD3, HB31C3A1CS, HB31C3ASDMB, HB31C4AS, PEXUSB311AC3, PEXUSB321C, S251BU31REM, S251BU31REMD, TB33A1C
- USB-C cable
- Technology
- Shielded
- Shielding Material
- Aluminum mylar foil with braid
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 24/30
- Plated Connector
- Nickel
- 10 Gbps data rate
- Length
- 50 cm
- Black
- 25 g
- Connector
- USB 3.1 Gen 2, RoHS, WEEE
- 2-year warranty
- Designed For
|  | StarTech.com 1m USB 3.1 C to Micro-B Cable | In Stock | £10.07 |
