Charge your USB 2.0 USB-C devices, with reduced clutter. This USB-C to USB-C cable makes it easy to charge and sync your USB 2.0, USB Type-C mobile devices using the USB-C port on your computer.
The cable is also compatible with Thunderbolt 3 ports, which means you can charge and sync your USB-C mobile devices using your Thunderbolt 3 laptop.
This non-standard 0.5-meter cable is great for close-range connections to charge and sync your USB Type-C mobile devices with your laptop.
You can also use the cable to charge your USB-C devices from a USB-C wall charger, car charger or power bank. It's the ideal cable for commuters for in-car use or to reduce clutter when syncing with your laptop.
With up to 3A of power output, you can use this USB Type-C cable to power a USB-C laptop, such as your Apple MacBook or Chromebook Pixel . Simply connect the cable to your USB-C laptop and to a USB-C wall charger.
Replace the USB-C charging cable that came with your device, or keep one as a spare while you're traveling, so that all of your devices will be ready to use whenever you need them while you're on the road.
- StarTech.com 0.5m USB C Cable - USB 2.0 - M/M - USB-C Charger Cable - USB 2.0 Type C Cable - Short USB C Cable (USB2CC50CM) - USB-C cable - 24 pin USB-C to 24 pin USB-C - 50 cm
- USB-C cable
- Technology
- Shielded
- Length
- 50 cm
- Connector
- 24 pin USB-C - male
- Connector (Second End)
- USB / USB 2.0
- Black
- Limited lifetime warranty
- Designed For
- P/N: DKT30CHD
- USB-C cable
- Technology
- Shielded
- Shielding Material
- Aluminum mylar foil with braid
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 22/30
- Plated Connector
- Nickel
- Length
- 50 cm
- Black
- 22 g
- Connector
- USB / USB 2.0, RoHS, WEEE
- Designed For
- P/N: DKT30CHD
StarTech.com USB-C Cable - M/M - 1m (3ft.) - USB 2.0 | In Stock | £9.47 |
StarTech.com 2m 6ft USB 2.0 USB-C Cable | In Stock | £11.21 |
StarTech.com 0.5m USB 2.0 USB C Cable | In Stock | £9.20 |
StarTech.com 1m Right Angle USB C Cable | In Stock | £11.21 |
StarTech.com 3m USB 2.0 Type C Cable | In Stock | £13.00 |
