StarTech.com 0.5m USB 2.0 USB C Cable
Quicklinx: CTWHWS00 Mfr#: USB2CC50CM
Length: 50cm
12 In Stock
£8.56 ex VAT
£10.27 inc VAT
Charge your USB 2.0 USB-C devices, with reduced clutter. This USB-C to USB-C cable makes it easy to charge and sync your USB 2.0, USB Type-C mobile devices using the USB-C port on your computer.
The cable is also compatible with Thunderbolt 3 ports, which means you can charge and sync your USB-C mobile devices using your Thunderbolt 3 laptop.
This non-standard 0.5-meter cable is great for close-range connections to charge and sync your USB Type-C mobile devices with your laptop.
You can also use the cable to charge your USB-C devices from a USB-C wall charger, car charger or power bank. It's the ideal cable for commuters for in-car use or to reduce clutter when syncing with your laptop.
With up to 3A of power output, you can use this USB Type-C cable to power a USB-C laptop, such as your Apple MacBook or Chromebook Pixel . Simply connect the cable to your USB-C laptop and to a USB-C wall charger.
Replace the USB-C charging cable that came with your device, or keep one as a spare while you're traveling, so that all of your devices will be ready to use whenever you need them while you're on the road.
  • Durable Construction
    The cable is made with a PVC jacket material that ensures longevity, while the aluminum mylar foil with braid shielding protects it from interference and enhances performance.
  • Versatile Connectivity
    Featuring 24-pin USB-C male connectors on both ends, this cable is compatible with a range of devices, making it a practical addition to any tech setup.
  • Efficient Data Transfer
    Compliant with USB 2.0 standards, this cable reliably supports data transfer and charging, allowing for effective performance with minimal downtime.
StarTech 0.5m USB C Cable - USB 2.0 - M/M - USB-C Charger Cable - USB 2.0 Type C Cable - Short USB C Cable (USB2CC50CM) - USB-C cable - USB-C to USB-C - 50 cm
USB-C cable
Shielded
Cable Length
50 cm
Connector
24 pin USB-C - male
Connector (Second End)
24 pin USB-C - male
USB / USB 2.0
P/N: DKT30CHD
USB-C cable
Shielded
Shielding Material
Jacket Material
PVC
American Wire Gauge (AWG)
22/30
Plated Connector
Nickel
Cable Length
50 cm
22 g
Connector
24 pin USB-C - male
24 pin USB-C - male
USB / USB 2.0, RoHS, WEEE
P/N: DKT30CHD
CTWH StarTech.com USB-C Cable - M/M - 1m (3ft.) - USB 2.0 In Stock £8.81
CTWH StarTech.com 2m 6ft USB 2.0 USB-C Cable In Stock £10.94
CTWH StarTech.com 0.5m USB 2.0 USB C Cable In Stock £8.56
CTWH StarTech.com 1m Right Angle USB C Cable In Stock £12.46
CTWH StarTech.com 3m USB 2.0 Type C Cable In Stock £11.30
Length: 50cm
