Charge your USB 2.0 USB-C devices, with reduced clutter. This USB-C to USB-C cable makes it easy to charge and sync your USB 2.0, USB Type-C mobile devices using the USB-C port on your computer.
The cable is also compatible with Thunderbolt 3 ports, which means you can charge and sync your USB-C mobile devices using your Thunderbolt 3 laptop.
This non-standard 0.5-meter cable is great for close-range connections to charge and sync your USB Type-C mobile devices with your laptop.
You can also use the cable to charge your USB-C devices from a USB-C wall charger, car charger or power bank. It's the ideal cable for commuters for in-car use or to reduce clutter when syncing with your laptop.
With up to 3A of power output, you can use this USB Type-C cable to power a USB-C laptop, such as your Apple MacBook or Chromebook Pixel . Simply connect the cable to your USB-C laptop and to a USB-C wall charger.
Replace the USB-C charging cable that came with your device, or keep one as a spare while you're traveling, so that all of your devices will be ready to use whenever you need them while you're on the road.
Durable Construction
The cable is made with a PVC jacket material that ensures longevity, while the aluminum mylar foil with braid shielding protects it from interference and enhances performance. -
Versatile Connectivity
Featuring 24-pin USB-C male connectors on both ends, this cable is compatible with a range of devices, making it a practical addition to any tech setup. -
Efficient Data Transfer
Compliant with USB 2.0 standards, this cable reliably supports data transfer and charging, allowing for effective performance with minimal downtime.
- StarTech.com 0.5m USB C Cable - USB 2.0 - M/M - USB-C Charger Cable - USB 2.0 Type C Cable - Short USB C Cable (USB2CC50CM) - USB-C cable - 24 pin USB-C to 24 pin USB-C - 50 cm
- USB-C cable
- Technology
- Shielded
- Length
- 50 cm
- Connector
- 24 pin USB-C - male
- Connector (Second End)
- USB / USB 2.0
- Black
- Limited lifetime warranty
- Designed For
- P/N: DKT30CHD
- USB-C cable
- Technology
- Shielded
- Shielding Material
- Aluminum mylar foil with braid
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 22/30
- Plated Connector
- Nickel
- Length
- 50 cm
- Black
- 22 g
- Connector
- USB / USB 2.0, RoHS, WEEE
- Designed For
- P/N: DKT30CHD
StarTech.com USB-C Cable - M/M - 1m (3ft.) - USB 2.0 | In Stock | £9.00 |
StarTech.com 2m 6ft USB 2.0 USB-C Cable | In Stock | £11.23 |
StarTech.com 0.5m USB 2.0 USB C Cable | In Stock | £8.74 |
StarTech.com 1m Right Angle USB C Cable | In Stock | £10.23 |
StarTech.com 3m USB 2.0 Type C Cable | In Stock | £11.56 |
