Charge and sync your USB 2.0 Micro-B devices from a USB-C host, with reduced clutter. This USB-C to Micro-B cable lets you charge and sync your USB 2.0 Micro-USB mobile device from a USB Type-C laptop, USB-C wall charger, car charger or power bank.
The cable also lets you connect an external Micro-USB drive for easy data backups.
This non-standard 0.5-meter cable is great for close-range connections to charge and sync your Micro-USB mobile devices with your laptop.
You can also use the cable to charge your devices from a USB-C wall charger, car charger or power bank - perfect for people on the move, for providing simple, tidy connections.
The cable can also be used to back up data from your USB-C or Thunderbolt 3 computer to an external Micro-USB 2.0 drive. The short cable lets you set up in small offsite workspaces, or in a coffee shop or hotel room, so that you can install your equipment without excess cable getting in your way.
Replace the USB-C charging cable that came with your device, or keep one as a spare while you're traveling, so that all of your devices will be ready to use whenever you need them while you're on the road.
- StarTech.com USB C to Micro USB Cable - 0.5m - M/M - Thunderbolt 3 Compatible - Micro USB Cord -USB Type C to Micro USB Cable (USB2CUB50CM) - USB-C cable - 24 pin USB-C to Micro-USB Type B - 50 cm
- USB-C cable
- Technology
- Shielded
- Sync and charge
- Length
- 50 cm
- Connector
- 24 pin USB-C - male
- Connector (Second End)
- 5 pin Micro-USB Type B - male
- USB / USB 2.0
- Black
- Limited lifetime warranty
- USB-C cable
- Technology
- Shielded
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 22/30
- Plated Connector
- Nickel
- Sync and charge
- Length
- 50 cm
- Black
- 20 g
- Connector
- USB / USB 2.0, RoHS, WEEE
StarTech.com 1m USB 2.0 C to Micro-USB Cable | In Stock | £9.63 |
StarTech.com 2m USB 2.0 C to Micro B Cable | In Stock | £12.66 |
StarTech.com 0.5m USB 2.0 C Micro-B Cable | In Stock | £8.61 |
