Charge and sync your USB 2.0 Micro-B devices from a USB-C host, with reduced clutter. This USB-C to Micro-B cable lets you charge and sync your USB 2.0 Micro-USB mobile device from a USB Type-C laptop, USB-C wall charger, car charger or power bank.
The cable also lets you connect an external Micro-USB drive for easy data backups.
This non-standard 0.5-meter cable is great for close-range connections to charge and sync your Micro-USB mobile devices with your laptop.
You can also use the cable to charge your devices from a USB-C wall charger, car charger or power bank - perfect for people on the move, for providing simple, tidy connections.
The cable can also be used to back up data from your USB-C or Thunderbolt 3 computer to an external Micro-USB 2.0 drive. The short cable lets you set up in small offsite workspaces, or in a coffee shop or hotel room, so that you can install your equipment without excess cable getting in your way.
Replace the USB-C charging cable that came with your device, or keep one as a spare while you're traveling, so that all of your devices will be ready to use whenever you need them while you're on the road.
Reliable performance
This cable complies with USB 2.0 standards, ensuring efficient data transfer rates for daily tasks. It is suitable for connecting various devices without compromising speed. -
Versatile connectivity
Featuring a 24 pin USB-C connector and a 5 pin Micro-USB Type-B connector, this cable enables compatibility with a wide range of devices, making it a valuable addition to any tech setup.
- StarTech.com USB C to Micro USB Cable - 0.5m - M/M - Thunderbolt 3 Compatible - Micro USB Cord -USB Type C to Micro USB Cable (USB2CUB50CM) - USB-C cable - 24 pin USB-C to Micro-USB Type B - 50 cm
- USB-C cable
- Technology
- Shielded
- Sync and charge
- Length
- 50 cm
- Connector
- 24 pin USB-C - male
- Connector (Second End)
- 5 pin Micro-USB Type B - male
- USB / USB 2.0
- Black
- Limited lifetime warranty
- USB-C cable
- Technology
- Shielded
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 22/30
- Plated Connector
- Nickel
- Sync and charge
- Length
- 50 cm
- Black
- 20 g
- Connector
- USB / USB 2.0, RoHS, WEEE
StarTech.com 1m USB 2.0 C to Micro-USB Cable | In Stock | £7.63 |
StarTech.com 2m USB 2.0 C to Micro B Cable | In Stock | £11.26 |
StarTech.com 0.5m USB 2.0 C Micro-B Cable | In Stock | £8.08 |
