StarTech.com 0.5m USB 2.0 A to B Cable - M/M
Quicklinx: 7W91WS00 Mfr#: USB2HAB50CM
Length: 50cm
Hurry, only 2 left in stock!
£3.13 ex VAT
£3.75 inc VAT
Connect USB 2.0 peripherals to your computer
The USB2HAB50CM 0.5-meter USB A-to-B cable features one USB ''A'' male connector and one USB ''B'' male connector, providing a high quality connection to USB 2.0 peripherals such as USB printers, scanners or external USB hard drives. Constructed of only top quality materials and expertly designed for durability, this USB 2.0 A-B cable is backed by StarTech.com''s Lifetime Warranty.
The StarTech.com Advantage
  • Short cable length provides maximum portability, making this an easy solution to store in a laptop bag or carrying case
  • Durable design, with high quality USB connectors
  • Backed by StarTech.com lifetime warranty
  • Reliable connectivity
    The 0.5 m USB 2.0 A to B Cable features male connectors on both ends, allowing for a secure connection between devices such as printers, scanners, and other peripherals.
  • High-speed data transfer
    Designed to support USB 2.0 standards, this cable ensures efficient data rates for seamless transfers, making it suitable for both professional and personal use.
  • Quality design
    With 24 AWG for power and 28 AWG for data, this cable is crafted to withstand regular use while providing performance and durability.
  • Environmental compliance
    The cable meets RoHS standards, ensuring it is free from hazardous materials, thereby promoting a safer environment.
StarTech.com 0.5m USB 2.0 A to B Cable M/M - USB cable - USB to USB Type B - 50 cm
USB cable
Length
50 cm
Connector
4 pin USB Type A - male
Connector (Second End)
4 pin USB Type B - male
USB / USB 2.0
USB cable
American Wire Gauge (AWG)
24/28
Length
50 cm
Connector
USB / USB 2.0, RoHS
7W91 StarTech.com 1m USB 2.0 A to B Cable - M/M In Stock £3.72
7W91 StarTech.com 2m USB 2.0 A to B Cable - M/M In Stock £3.84
7W91 StarTech.com 3m USB 2.0 A to B Cable - M/M In Stock £4.29
7W91 StarTech.com 0.5m USB 2.0 A to B Cable - M/M In Stock £3.13
7W91 StarTech.com 5m USB 2.0 A to B Cable - M/M In Stock £5.64
Length: 50cm
