Brand
StarTech.com 0.5m Thunderbolt 3 Cable White
Quicklinx: CY2NWS00 Mfr#: TBLT34MM50CW
Length: 50cm
14 in stock
£19.56 ex VAT
£23.47 inc VAT
Provide four times the data transfer speed of any other cable type, enable dual 4K 60Hz video, and power your devices with a single cable. This Thunderbolt 3 cable lets you connect to any Thunderbolt 3 port (USB-C) to deliver video and data to your Thunderbolt, USB and DisplayPort devices. Plus, the cable can provide power for charging your devices, and you can link up to six Thunderbolt 3 devices as part of a daisy-chained connection.
This cable supports data transfer rates of 40Gbps when connected to a Thunderbolt 3 device, so you can transfer photo and video files at four times the speed of a USB 3.1 Gen 2 (10Gbps) cable. For example, you can transfer a 4K movie in seconds. When connected to a USB 3.1 device, the cable supports data transfer rates of 10Gbps.
The Thunderbolt 3 USB-C cable is fully compatible with all of your USB 3.1 Gen 2 devices and can be used for charging and syncing your mobile devices. You can also connect and power USB-C laptops, such as your MacBook Pro, Chromebook, and USB-C peripherals, such as your portable drive or docking station.
The cable supports full 4K 60Hz or 5K 60Hz video. The cable also supports DisplayPort 1.2 and is compatible with existing DisplayPort displays. It's perfect for connecting your docking station or laptop to a monitor with astonishing resolution, contrast, and color depth for amazing detail.
This Thunderbolt 3 cable delivers up to 100W of power for charging a laptop or powering a display, and 15W for bus-powered devices such as a hard drive enclosure.
The cable gives you an easy way to bridge multiple Thunderbolt 3 enabled laptops for peer-to-peer 10GbE networking. It's perfect for setting up small workgroups and sharing peripherals such as printers and storage. You can also connect two Thunderbolt 3 laptops together for PC migrations.
  • Faster data transfers when connected to Thunderbolt devices
  • USB-C compatible
  • Full 4K video
  • Versatile power delivery
  • Thunderbolt networking
StarTech.com 40Gbps Thunderbolt 3 Cable - 1.6ft/0.5m - White - 5k 60Hz/4k 60Hz - Certified TB3 USB-C Charger Cord w/ 100W Power Delivery (TBLT34MM50CW) - Thunderbolt cable - USB-C to USB-C - 50 cm
Thunderbolt cable
4K support, 5K support
Length
50 cm
Connector
24 pin USB-C - male
Connector (Second End)
24 pin USB-C - male
USB 3.1 Gen 2 / Thunderbolt 3 / DisplayPort 1.2
White
P/N: CDP2HDUACP, CDP2HDUACPW, PEXUSB321C, TB33A1C
Thunderbolt cable
Length
50 cm
White
Connector
24 pin USB-C - male
24 pin USB-C - male
CY2N StarTech.com 0.5m Thunderbolt 3 Cable In Stock £19.56
CY2N StarTech.com 0.5m Thunderbolt 3 Cable White In Stock £19.56
Length: 50cm
Stock Status: In stock
