Provide four times the data transfer speed of any other cable type, enable dual 4K 60Hz video, and power your devices with a single cable. This Thunderbolt 3 cable lets you connect to any Thunderbolt 3 port (USB-C) to deliver video and data to your Thunderbolt, USB and DisplayPort devices. Plus, the cable can provide power for charging your devices, and you can link up to six Thunderbolt 3 devices as part of a daisy-chained connection.
This cable supports data transfer rates of 40Gbps when connected to a Thunderbolt 3 device, so you can transfer photo and video files at four times the speed of a USB 3.1 Gen 2 (10Gbps) cable. For example, you can transfer a 4K movie in seconds. When connected to a USB 3.1 device, the cable supports data transfer rates of 10Gbps.
The Thunderbolt 3 USB-C cable is fully compatible with all of your USB 3.1 Gen 2 devices and can be used for charging and syncing your mobile devices. You can also connect and power USB-C laptops, such as your MacBook Pro, Chromebook, and USB-C peripherals, such as your portable drive or docking station.
The cable supports full 4K 60Hz or 5K 60Hz video. The cable also supports DisplayPort 1.2 and is compatible with existing DisplayPort displays. It's perfect for connecting your docking station or laptop to a monitor with astonishing resolution, contrast, and color depth for amazing detail.
This Thunderbolt 3 cable delivers up to 100W of power for charging a laptop or powering a display, and 15W for bus-powered devices such as a hard drive enclosure.
The cable gives you an easy way to bridge multiple Thunderbolt 3 enabled laptops for peer-to-peer 10GbE networking. It's perfect for setting up small workgroups and sharing peripherals such as printers and storage. You can also connect two Thunderbolt 3 laptops together for PC migrations.
Faster data transfers when connected to Thunderbolt devices
This cable supports data transfer rates of 40Gbps when connected to a Thunderbolt 3 device, so you can transfer photo and video files at four times the speed of a USB 3.1 Gen 2 (10Gbps) cable. For example, you can transfer a 4K movie in seconds. When connected to a USB 3.1 device, the cable supports data transfer rates of 10Gbps. -
USB-C compatible
The Thunderbolt 3 USB-C cable is fully compatible with all of your USB 3.1 Gen 2 devices and can be used for charging and syncing your mobile devices. You can also connect and power USB-C laptops, such as your MacBook Pro, Chromebook , and USB-C peripherals, such as your portable drive or docking station. -
Full 4K video
The cable supports full 4K 60Hz or 5K 60Hz video. The cable also supports DisplayPort 1.2 and is compatible with existing DisplayPort displays. It's perfect for connecting your docking station or laptop to a monitor with astonishing resolution, contrast, and color depth for amazing detail. -
Versatile power delivery
This Thunderbolt 3 cable delivers up to 100W of power for charging a laptop or powering a display, and 15W for bus-powered devices such as a hard drive enclosure. -
Thunderbolt networking
The cable gives you an easy way to bridge multiple Thunderbolt 3 enabled laptops for peer-to-peer 10GbE networking. It's perfect for setting up small workgroups and sharing peripherals such as printers and storage. You can also connect two Thunderbolt 3 laptops together for PC migrations. The TBLT34MM50CW is backed by a 2-year warranty.
- StarTech.com 1.6ft (50cm) Thunderbolt 3 Cable, 40Gbps, 100W PD, 4K/5K Video, Thunderbolt-Certified, Compatible w/ TB4/USB 3.2/DisplayPort - Thunderbolt cable - 24 pin USB-C to 24 pin USB-C - 50 cm
- Thunderbolt cable
- 4K support, 5K support
- Length
- 50 cm
- Connector
- 24 pin USB-C - male
- Connector (Second End)
- USB 3.1 Gen 2 / Thunderbolt 3 / DisplayPort 1.2
- White
- 2-year warranty
- Designed For
- P/N: CDP2HDUACP, CDP2HDUACPW, PEXUSB321C, TB33A1C
- Thunderbolt cable
- Length
- 50 cm
- White
- Connector
- 2-year warranty
- Designed For
StarTech.com 2m Thunderbolt 3 20Gbps Cable | In Stock | £39.59 |
StarTech.com 0.5m Thunderbolt 3 Cable | In Stock | £19.71 |
StarTech.com 0.8m / 2.7ft Thunderbolt 3 to Thunderbolt 3 Cable - 40Gbps | In Stock | £31.79 |
StarTech.com 3ft USB4 Cable, USB-C 40 Gbps | In Stock | £20.93 |
StarTech.com 6ft (2m) Thunderbolt Cable | In Stock | £80.26 |
StarTech.com 1m USB4 Cable, USB-C 40 Gbps | In Stock | £20.77 |
StarTech.com 1.6ft USB4 Cable, USB-C 40Gbps | In Stock | £19.63 |
