100% copper for outstanding value
Get the highest value for your cable investment with Cat 6 cables, each one manufactured using high-quality copper conductors.
24-gauge wire for high-performance network connections
50-micron gold connectors provide peak conductivity
Rely on RJ45 connectors to deliver optimum conductivity while eliminating signal loss due to oxidation or corrosion.
Lifetime Warranty
StarTech.com back all cables with a lifetime warranty.
Reliable connectivity
The 50 cm CAT6 Ethernet Cable is crafted with UTP technology, ensuring stable network connections for various devices. -
Easy installation
Molded ends and a snagless design help prevent damage to ports, allowing for straightforward setup. -
Power over Ethernet
With PoE readiness, this cable can simultaneously carry power and data, enhancing its functionality. -
Durable construction
The PVC jacket and gold-plated connectors ensure that this cable can withstand regular use while maintaining performance. -
Compliance assured
This cable adheres to RoHS, ETL, and TIA/EIA-568-B standards, making it a trustworthy choice for networking needs.
- Startech 50cm CAT6 Ethernet Cable, 10 Gigabit Snagless RJ45 650MHz 100W PoE Patch Cord, CAT 6 10GbE UTP Network Cable w/Strain Relief, Red, Wiring is UL Certified/TIA - Category 6 - 24AWG (N6PATC50CMRD) - network cable - 50 cm - red
- Network cable - CAT 6
- Technology
- Wiring Scheme
- T568B
- Wires per Cable
- 8 wires
- Molded, snagless, stranded, strain relief, PoE ready
- Cable Length
- 50 cm
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- Red
- Limited lifetime warranty
- Network Cable Type
- Technology
- Wiring Scheme
- T568B
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 24
- Wires per Cable
- 8 wires
- Pairs per Cable
- 4 pairs
- Plated Connector
- Gold
- Cable Length
- 50 cm
- 26 g
- Red
- Connector
- RJ-45 - male
- RJ-45 - male
- RoHS, ETL, TIA/EIA-568-B - up to 500 MHz
StarTech.com 0.5m Blue Gigabit Snagless RJ45 UTP Cat6 Patch Cable | In Stock | £3.70 |
StarTech.com 0.5m Black Gigabit Snagless RJ45 UTP Cat6 Patch Cable | In Stock | £3.59 |
StarTech.com 0.5m Gray Cat6 Patch Cable | In Stock | £3.70 |
StarTech.com 0.5m Green Cat6 Patch Cable | In Stock | £3.70 |
StarTech.com 0.5m Orange Cat6 Patch Cable | In Stock | £3.70 |
StarTech.com 0.5m Purple Cat6 Patch Cable | In Stock | £3.70 |
StarTech.com 0.5m Red Cat6 Patch Cable | In Stock | £3.70 |
StarTech.com 0.5m White Cat6 Patch Cable | In Stock | £3.59 |
StarTech.com 0.5m Yellow Cat6 Patch Cable | In Stock | £3.70 |
