StarTech.com 0.5m Red Cat6 Patch Cable
Quicklinx: CNDBWS00 Mfr#: N6PATC50CMRD
Length: 50cm
Colour: Red
More than 50 in stock
£2.99 ex VAT
£3.58 inc VAT
100% copper for outstanding value
Get the highest value for your cable investment with Cat 6 cables, each one manufactured using high-quality copper conductors.
24-gauge wire for high-performance network connections
50-micron gold connectors provide peak conductivity
Rely on RJ45 connectors to deliver optimum conductivity while eliminating signal loss due to oxidation or corrosion.
Lifetime Warranty
StarTech.com back all cables with a lifetime warranty.
StarTech.com 50cm CAT6 Ethernet Cable, 10 Gigabit Snagless RJ45 650MHz 100W PoE Patch Cord, CAT 6 10GbE UTP Network Cable w/Strain Relief, Red, Fluke Tested/Wiring is UL Certified/TIA - Category 6 - 24AWG (N6PATC50CMRD) - network cable - 50 cm - red
Network cable - CAT 6
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Wires per Cable
8 wires
Molded, snagless, stranded, strain relief, PoE ready
Length
50 cm
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Red
Network Cable Type
Wiring Scheme
T568B
Jacket Material
PVC
American Wire Gauge (AWG)
24
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
50 cm
26 g
Red
Connector
RJ-45 - male
RJ-45 - male
RoHS, ETL, TIA/EIA-568-B - up to 500 MHz
CNDB StarTech.com 0.5m Blue Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £2.86
CNDB StarTech.com 0.5m Black Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £0.95
CNDB StarTech.com 0.5m Gray Cat6 Patch Cable In Stock £2.99
CNDB StarTech.com 0.5m Green Cat6 Patch Cable In Stock £2.99
CNDB StarTech.com 0.5m Orange Cat6 Patch Cable In Stock £2.99
CNDB StarTech.com 0.5m Purple Cat6 Patch Cable In Stock £2.99
CNDB StarTech.com 0.5m Red Cat6 Patch Cable In Stock £2.99
CNDB StarTech.com 0.5m Yellow Cat6 Patch Cable In Stock £2.99
Length: 50cm
Colour: Red
Stock Status: In stock
