StarTech.com 0.5m Red Cat5e Patch Cable
Quicklinx: CRFMWS00 Mfr#: 45PAT50CMRD
Length: 50cm
Colour: Red
More than 50 In Stock
£2.49 ex VAT
£2.98 inc VAT
The wide selection of Cat 5e patch cables makes it easy to find the lengths and colors that you need to complete your network connections.
These Ethernet cables are:
  • Durable. All of the patch cables are constructed to the highest industry standards, to ensure high-quality installs.
  • Dependable. You can rely on these Cat 5e cables to deliver the stability and speed that you need for reliable network performance.
  • Backed by a lifetime manufacturer warranty. All of these network cables are guaranteed to last as long as you need them.
Startech 0.5m Red Cat5e / Cat 5 Snagless Ethernet Patch Cable 0.5 m - patch cable - 50 cm - red
Patch cable - CAT 5e
Unshielded twisted pair (UTP)
Snagless, stranded, PoE ready
Cable Length
50 cm
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Red
Network Cable Type
Jacket Material
PVC
American Wire Gauge (AWG)
24
Plated Connector
Copper
Cable Length
50 cm
26 g
Red
Connector
RJ-45 - male
RJ-45 - male
Up to 350 MHz
CRFM StarTech.com 0.5m Blue Cat5e Patch Cable In Stock £4.00
CRFM StarTech.com 0.5m Green Cat5e Patch Cable In Stock £2.44
CRFM StarTech.com 0.5m Red Cat5e Patch Cable In Stock £2.49
CRFM StarTech.com 0.5m White Cat5e Patch Cable In Stock £3.99
CRFM StarTech.com 0.5m Yellow Cat5e Patch Cable In Stock £3.99
CRFM StarTech.com 0.5m Gray Cat5e Patch Cable In Stock £3.99
CRFM StarTech.com 0.5m Orange Cat5e Patch Cable In Stock £2.44
CRFM StarTech.com 0.5m Black Cat5e Patch Cable In Stock £3.99
Length: 50cm
Colour: Red
