StarTech.com 0.5m Orange Cat5e Patch Cable
Quicklinx: CRFZWS00 Mfr#: 45PAT50CMOR
Length: 50cm
Colour: Orange
More than 50 in stock
£2.55 ex VAT
£3.06 inc VAT
The wide selection of Cat 5e patch cables makes it easy to find the lengths and colors that you need to complete your network connections.
These Ethernet cables are:
  • Durable. All of the patch cables are constructed to the highest industry standards, to ensure high-quality installs.
  • Dependable. You can rely on these Cat 5e cables to deliver the stability and speed that you need for reliable network performance.
  • Backed by a lifetime manufacturer warranty. All of these network cables are guaranteed to last as long as you need them.
StarTech.com 0.5m Orange Cat5e / Cat 5 Snagless Ethernet Patch Cable 0.5 m - patch cable - 50 cm - orange
Patch cable - CAT 5e
Unshielded twisted pair (UTP)
Snagless, stranded, PoE ready
Length
50 cm
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Orange
Network Cable Type
Jacket Material
PVC
American Wire Gauge (AWG)
24
Plated Connector
Copper
Length
50 cm
26 g
Orange
Connector
RJ-45 - male
RJ-45 - male
Up to 350 MHz
CRFZ StarTech.com 0.5m Blue Cat5e Patch Cable In Stock £2.55
CRFZ StarTech.com 0.5m Green Cat5e Patch Cable In Stock £2.55
CRFZ StarTech.com 0.5m White Cat5e Patch Cable In Stock £2.57
CRFZ StarTech.com 0.5m Yellow Cat5e Patch Cable In Stock £2.55
CRFZ StarTech.com 0.5m Gray Cat5e Patch Cable In Stock £2.55
CRFZ StarTech.com 0.5m Orange Cat5e Patch Cable In Stock £2.55
CRFZ StarTech.com 0.5m Black Cat5e Patch Cable In Stock £2.55
Length: 50cm
Colour: Orange
Price Range Ex VAT: 0 - 50
