Charge or sync your portable Micro USB devices at short distances, with the cable kept out of the way. The USBAUB50CMD 0.5m USB to Down Angle Micro USB Cable provides a high quality connection between your Micro USB 2.0 mobile devices (smartphones, digital cameras, Tablet PC devices, portable hard drives, etc.) and your PC or Mac computer, for everyday tasks such as charging, data synchronization or file transfers.
The down-angled Micro USB connector allows you to access your mobile Micro USB devices, while keeping the cable out of the way, and stress away from the port.
Perfect for close-range device connections, StarTech.com shorter micro USB cables provide a portable solution that makes them perfect for carrying as an accessory for your tablet or laptop.
As an alternative, StarTech.com also offers a 0.5m USB to Up Angle Micro USB Cable (USBAUB50CMU), which provides the same convenience as this down-angled cable, but allows you to connect to your Micro USB device from the opposite direction.
- StarTech.com 0.5m Micro USB Cable - A to Down Angle Micro B - USB cable - Micro-USB Type B to USB - 50 cm
- USB cable
- Technology
- Double shielded
- 90° connector, molded, strain relief
- Length
- 50 cm
- Connector
- 5 pin Micro-USB Type B - male
- Connector (Second End)
- 4 pin USB Type A - male
- USB / USB 2.0
- Black
- Limited lifetime warranty
- USB cable
- Technology
- Double shielded
- American Wire Gauge (AWG)
- 28
- Plated Connector
- Nickel
- Length
- 50 cm
- Black
- Connector
- USB / USB 2.0, RoHS
