The HDADMM50CM 0.5-meter/50cm High Speed HDMI to HDMI Micro cable enables you to connect devices with an HDMI Micro port to a display/device with a standard HDMI port - a cost-saving solution for connecting cutting-edge and next-generation HDMI-capable devices to existing HDMI technology. The HDMI/HDMI Micro cable features high-quality gold-tipped connectors that ensure peak connectivity.
Versatile connectivity
This cable features a 19-pin HDMI Type-A connector and a 19-pin micro HDMI Type D connector, allowing compatibility with multiple devices such as camcorders and tablets. -
Enhanced video performance
With support for 3D-Transmission technology, this cable is ideal for delivering high-quality visuals, making it suitable for gaming and media applications. -
Durable construction
The PVC jacket and gold-plated connectors contribute to the cable's robustness, ensuring it can endure frequent plugging and unplugging without loss of functionality.
- StarTech.com 0.5m High Speed HDMI Cable with Ethernet HDMI to HDMI Micro - HDMI cable with Ethernet - 50 cm
- Cable
- American Wire Gauge (AWG)
- 34
- Length
- 50 cm
- Black
- Connector
- HDMI - male
- Connector (Second End)
- 19 pin micro HDMI Type D - male
- 3D-Transmission
- Limited lifetime warranty
- Cable Type
- 34
- Jacket Material
- PVC
- Length
- 50 cm
- Plated Connector
- Gold
- 3D-Transmission
- Black
- Connector
- 19 pin HDMI Type A - male
- RoHS
- Limited warranty - lifetime
StarTech.com 1m High Speed HDMI Cable with Ethernet - HDMI to HDMI Micro - M/M | In Stock | £7.51 |
StarTech.com 2m High Speed HDMI Cable with Ethernet - HDMI to HDMI Micro - M/M | In Stock | £8.69 |
StarTech.com 0.5m High Speed HDMI Cable with Ethernet - HDMI to HDMI Micro - M/M | In Stock | £5.74 |
StarTech.com 3m High Speed HDMI Cable with Ethernet - HDMI to HDMI Micro - M/M | In Stock | £10.03 |
