Connect your DVI-D or HDMI-enabled display with reduced clutter. The HDDVIMM50CM 0.5m HDMI to DVI-D cable allows you to connect an HDMI-enabled device to a DVI-D display, or a DVI-D device to an HDMI-capable display at shorter distances and with reduced clutter.
Ideal for close-range device connections, this short HDMI to DVI cable provides a portable solution that makes it perfect for carrying as an accessory for your laptop.
- StarTech.com 0.5m HDMI to DVID Cable M/M - adapter cable - HDMI / DVI - 50 cm
- Cable
- Adapter cable - HDMI / DVI
- Technology
- Double shielded
- American Wire Gauge (AWG)
- 28
- Length
- 50 cm
- Black
- Connector
- DVI-D - male
- Connector (Second End)
- HDMI - male
- Moulded, strain relief
- Limited lifetime warranty
- Cable Type
- Adapter cable
- Interface Supported
- HDMI / DVI
- Technology
- Double shielded
- 28
- Jacket Material
- PVC
- Shielding Material
- Aluminum mylar foil with braid
- Length
- 50 cm
- Plated Connector
- Gold
- Black
- Connector
- 18+1 pin digital DVI (Single-Link) - male
- 19 pin HDMI Type A - male
- RoHS
- Limited warranty - lifetime
StarTech.com 10m HDMI to DVI-D Cable - M/M | In Stock | £58.94 |
StarTech.com 2m High Speed HDMI® Cable to DVI Digital Video Monitor | In Stock | £8.82 |
StarTech.com 3m HDMI to DVI-D Cable - M/M | In Stock | £9.75 |
StarTech.com 5m HDMI to DVI-D Cable – M/M | In Stock | £18.49 |
StarTech.com 1m HDMI to DVI-D Cable - M/M | In Stock | £7.62 |
StarTech.com 1.5m HDMI to DVI-D Cable - M/M | In Stock | £11.20 |
StarTech.com 7m HDMI to DVI-D Cable - M/M | In Stock | £14.28 |
