StarTech.com 0.5m HDMI to DVI-D Cable - M/M
Quicklinx: 9F5SWS00 Mfr#: HDDVIMM50CM
Length: 50cm
Hurry, only 2 left in stock!
£7.60 ex VAT
£9.12 inc VAT
Connect your DVI-D or HDMI-enabled display with reduced clutter. The HDDVIMM50CM 0.5m HDMI to DVI-D cable allows you to connect an HDMI-enabled device to a DVI-D display, or a DVI-D device to an HDMI-capable display at shorter distances and with reduced clutter.
Ideal for close-range device connections, this short HDMI to DVI cable provides a portable solution that makes it perfect for carrying as an accessory for your laptop.
  • High-quality connectivity
    The 0.5m HDMI to DVID Cable M/M from StarTech.com ensures a reliable connection between HDMI and DVI devices. Featuring gold-plated connectors and double-shielded technology, this cable provides superior signal transmission for high-definition video without interference.
  • Durable design
    Designed with durability in mind, the cable boasts a PVC jacket, aluminum mylar foil with braid shielding, and strain relief. These features protect against physical strain and signal loss, ensuring longevity and consistent performance.
  • Versatile compatibility
    With one 18+1 pin digital DVI (Single-Link) male connector and one 19-pin HDMI Type-A male connector, this video adapter cable is compatible with a wide range of devices. It supports seamless connectivity between HDMI and DVI interfaces, making it a versatile addition to your multimedia setup.
StarTech.com 0.5m HDMI to DVID Cable M/M - adapter cable - HDMI / DVI - 50 cm
Cable
Adapter cable - HDMI / DVI
Double shielded
American Wire Gauge (AWG)
28
Length
50 cm
Connector
DVI-D - male
Connector (Second End)
HDMI - male
Moulded, strain relief
Cable Type
Adapter cable
Interface Supported
HDMI / DVI
Double shielded
28
Jacket Material
PVC
Shielding Material
Length
50 cm
Plated Connector
Gold
Connector
18+1 pin digital DVI (Single-Link) - male
19 pin HDMI Type A - male
RoHS
Limited warranty - lifetime
9F5S StarTech.com 2m High Speed HDMI® Cable to DVI Digital Video Monitor In Stock £7.77
9F5S StarTech.com 3m HDMI to DVI-D Cable - M/M In Stock £9.62
9F5S StarTech.com 5m HDMI to DVI-D Cable – M/M In Stock £9.52
9F5S StarTech.com 1m HDMI to DVI-D Cable - M/M In Stock £7.29
9F5S StarTech.com 1.5m HDMI to DVI-D Cable - M/M In Stock £7.91
Length: 50cm
