StarTech.com 0.5m Gray Cat6a Cable STP
Quicklinx: CZC6WS00 Mfr#: 6ASPAT50CMGR
Length: 50cm
Colour: Grey
23 In Stock
£7.71 ex VAT
£9.25 inc VAT
Deliver high-performance 10 Gigabit network connections, free of noise and EMI/RFI interference. This Cat6a cable meets or exceeds all Category 6a cable specifications to ensure reliable 10Gb network connections. The cable is shielded to protect your network against electromagnetic interference (EMI/RFI) and system noise, providing the perfect solution for fast and safe network connections.
This 0.5-meter gray patch cable is perfect for use in server closets, patch panels and with Ethernet hubs. The cable is intended for short-distance applications such as point-to-point in-rack and across-rack network switch and server connections.
For easier network installations, the Cat6a patch cables are available in a wide variety of lengths and colors. This ensures you have the right size of cable available when you need it and it lets you color code your connections for a more organized setup.
Each cable is tested for up to 500MHz frequency and is more than suitable for 10GBase-T Ethernet networks.
Constructed with 100% copper and foil-shielded, twisted-pair wiring, this cable was built for quality performance. The cable is designed to keep the data signals traveling through your network free from interference and is perfect in environments that are prone to large amounts of EMI.
The 50-micron gold connectors deliver optimum conductivity and eliminate signal loss due to oxidation or corrosion.
For trouble-free cable runs, this durable cable features snagless connectors that protect the RJ45 clips during installation, making them less likely to snag or break.
The cable also features molded boots which offer connector strain relief by stopping the RJ45 connector termination points from bending at sharp angles. This reduces the risk of damage to the cable, which could decrease network connectivity and performance.
  • High-capacity performance
    This CAT6A Ethernet cable supports frequencies up to 500 MHz, enabling rapid data transfer and efficient network performance.
  • Sturdy construction
    Constructed with a PVC jacket and aluminum-polyester foil shielding, this cable provides durability and reliable resistance against external interference.
  • Versatile connectivity
    Each end of the cable is equipped with male RJ-45 connectors, ensuring compatibility with standard network devices for flexible applications.
StarTech.com 50cm CAT6A Ethernet Cable, 10 Gigabit Shielded Snagless RJ45 100W PoE Patch Cord, CAT 6A 10GbE STP Network Cable w/Strain Relief, Grey, Fluke Tested/UL Certified Wiring/TIA - Category 6A - 26AWG (6ASPAT50CMGR) - patch cable - 50 cm - grey
Patch cable - CAT 6a
Shielded twisted pair (STP)
Shielding Material
Aluminium-polyester foil
Wires per Cable
8 wires
Snagless, strain relief, PoE ready, RFI/EMI shielding
Length
50 cm
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Grey
Network Cable Type
Shielding Material
Jacket Material
PVC
American Wire Gauge (AWG)
25
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Length
50 cm
Grey
Connector
RJ-45 - male
RJ-45 - male
RoHS, WEEE - up to 500 MHz
CZC6 StarTech.com 0.5m Aqua Cat6a Cable STP In Stock £7.89
CZC6 StarTech.com 0.5m Black Cat6a Cable STP In Stock £7.89
CZC6 StarTech.com 0.5m Blue Cat6a Cable STP In Stock £7.71
CZC6 StarTech.com 0.5m Gray Cat6a Cable STP In Stock £7.71
Length: 50cm
Colour: Grey
