StarTech.com 0.5m Coax High Resolution Monitor VGA Video Cable - HD15 M/M
Quicklinx: 84NDWS00 Mfr#: MXTMMHQ50CM
Length: 50cm
More than 50 in stock
£5.26 ex VAT
£6.31 inc VAT
Connect your VGA monitor with the highest quality connection available. The MXTMMHQ50CM 0.5m High Resolution VGA Cable (50cm) is designed to provide the highest video quality possible through VGA, ideally suited for high resolution applications of 1920x1200 and above.
This durably constructed coaxial VGA video cable (HD15 to HD15) eliminates the picture "ghosting" and fuzzy images that are inherent to non-coaxial VGA cables, while delivering superior EMI interference protection by using ferrite cores near the connector ends.
StarTech.com 0.5m Coax High Resolution Monitor VGA Video Cable HD15 M/M - VGA cable - 50 cm
VGA cable
Triple shielded twisted pair coaxial
Molded, thumbscrews, strain relief, ferrite core
Length
50 cm
Connector
HD-15 (VGA) - male
Connector (Second End)
HD-15 (VGA) - male
UL 2919, RoHS, NEC-CMG
VGA cable
Shielding Material
American Wire Gauge (AWG)
28
Plated Connector
Nickel
Length
50 cm
Connector
Length: 50cm
Stock Status: In stock
